Crochet Pastel Baby Blanket
Published
Introduction: Crochet Pastel Baby Blanket
About: A Software Engineer. I love learning new things. Hooked up with Instructables. It is the biggest find I ever made. :D Cooking and Crochet are my passion. I love to learn different techniques and cuisines.
This is a special make for my baby due December. So this blanket always remains close to my heart. As I write this instructables I am in my 37th week and all set with this blanket to welcome my little one.
It is a granny square blanket given with a good lace border.
I love pastel colors and I have used the same color tone. It is simple but time consuming. Hope you like this article.
Step 1: Material
Materials:
Worsted Weight Yarn - Cream, pink, Light purple, light green
Size U.S. I/9 (5.50mm)
Scissors
Tapestry Needle
Abbreviation (US terms):
sl knot = slip knot
slst = slip stitch
ch = chain
dc = double crochet
tr = treble (triple) crochet
st = stitch sts = stitches
fo = fasten off
Step 2: Granny Square - 1
Round 1: sl knot, ch4, dc 11 on the 4th ch from the hook. slst to the ch at the beginning of the round.
Round 2: ch5, tr into the same st at the beginning of the round, 2dc in each st for the next 2 sts, *tr+ ch2+tr into the next st, 2dc in each st for the next 2 sts, repeat 3 times till you have 4 corners done. slst to the ch space at the beginning of the round.
Step 3: Granny Square - 2
Round 3: ch5, tr into the same ch
space at the beginning of the round, 2dc in next st, dc in each st for the next 4 sts, 2dc in next st, *tr+ ch2+tr into the ch space of the corner, 2dc in next st, dc in each st for the next 4 sts, 2dc in next st, repeat 3 times till you have 4 corners done. slst to the ch space at the beginning of the round.
Round 4: ch5, tr into the same ch space at the beginning of the round, 2dc in next st, dc in each st for the next 8 sts, 2dc in next st, *tr+ ch2+tr into the ch space of the corner, 2dc in next st, dc in each st for the next 8 sts, 2dc in next st, repeat 3 times till you have 4 corners done. slst to the ch space at the beginning of the round.
Step 4: Granny Square - 3
Round 5: ch5, tr into the same ch
space at the beginning of the round, 2dc in next st, dc in each st for the next 12 sts, 2dc in next st, *tr+ ch2+tr into the ch space of the corner, 2dc in next st, dc in each st for the next 12 sts, 2dc in next st, repeat 3 times till you have 4 corners done. slst to the ch space at the beginning of the round
Step 5: Joining the Squares Together
There are different ways you can join the squares.
I used the most simple method. You can connect two squares using the slip stitch or the Single crochet. So when you use that there would be a small edging along the sides of the squares.
Step 6: Edging
You can give any edging you like. I have given a simple lace effect edging.
Pretty lacy edging:
Round 1: Join edge yarn and sc in each stitch around the blanket, join with ss to finish the round. I went with 3 sc in each corner, but just add enough stitches to the corner so it stays flat and doesn’t pull.
Round 2: Chain 5, skip next 4 sc, (dc, ch3, dc) in next sc, ch 5, skip next 4 sc, sc in next sc. repeat around, join with ss to finish the round.
Round 3: Chain 5, sc in next ch-5 space, 3dc, ch3, 3dc in next ch-3 space, sc in next ch-5 space, repeat around, join with ss to finish the round.
Round 4: Ch1, *sc in next 5ch, dc in next dc, picot, dc in next dc, dc in next dc, picot, (2dc, picot, 2dc) in next ch3 space, picot, dc in next dc, dc in next dc, picot, dc in next dc, sc in next ch5 space* Repeat between * and * around. Join with ss into ch1 to finish the round.
    • Stick It! Contest
      Stick It! Contest
    • BBQ Showdown Challenge
    • Backpack Challenge
      Backpack Challenge
    3 Discussions
    I haven't seen granny squares connect like this before, I really like it!
    Beautiful Blanket, I love the pretty lace border!
