Crocheted Head Warmer
Published
Introduction: Crocheted Head Warmer
This head warmer is made using the double stich.
It is very easy and is suggested for beginners.
Step 1: What You Will Need:
For this project you will need , yarn (chunky works well) ,crochet hook, darning needle, and sissors
Step 2: Getting Started
Chain 40 with your yarn .
Step 3: Row One
Double crochet first row.
Double Crochet stich (first stich)
Yarn over an insert the crochet hook into third chain skipping two chains .Yarn over again pull through one loop on your hook yarn over again pull through two loops yarn over again pull through the rest of the loops.Double crochet first row.
Double Crochet stich (second stich )
Yarn over insert the hook into the next stich .Yarn over again pull through one loop on your hook yarn over again pull through two loops yarn over again pull through the rest of the loops.
Step 4: Rows 2 -3
Continue to double crochet until you get to the end of the row than chain 2 and double crochet into the first stich.
Step 5: Last Row
Double crochet the rest of row four
You need the head warmer to be at least 3 inches wide
To End,
Chain 2 cut four inches from the last chain then pull the chain on the hook until it knots
Step 6: Finishing Up
Thread darning needle with tail yarn. Weave in loose ends. Trim off .
Take a 21 inch piece of the same yarn to sew up the sides.
Whip stich the sides together. Weave in loose ends from the sewing together of the sides.
Step 7: Final Product
Turn inside out so that the stitching is in .
And your done.!!!!
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
