loading
Step 2: Mix the Dough
Combine the ingredients in a large mixing bowl.
Start with the warm water, and add the yeast to it. Stir.
Add flour a cup at a time and mix. Add in the salt as you are doing this. Once you get in 3 cups of flour, keeping adding more flour in small amounts and mixing until the dough no longer sticks to the side of the mixing bowl. This might be an entire cup or more of flour.
Sprinkle a little flour over the top of the dough, then cover it with plastic wrap, and set out-of-the-way for 8 to 12 hours. I usually prepare the dough the night before I need it, and bake it the next day.
Wonderful! I tried it last week and it was fantastic!! I added a link to this site from my blog, so others could give it a go. (I have weird friends who like to try stuff like this.) :)
<p>Look up retained heat cooking for ideas to insulate your crock pot. Or make a wonder bag for it. I did an instructable for a hay box cooker that might give you some ideas. Hope it helps you. </p>
<p>I've been trying this crock pot/double pot method to make clotted cream. What do you think about using the double pot without the water in the bottom? the problem with water in the pot is that it creates too much steam which in turn drips on the cream.</p>
With a doubled pot and no water, heat won't transfer correctly. The heating element in Crock-Pots is in the side only. The instructions always say that you MUST have water or liquid in the crock, or you can damage it.<br><br>You might just want to try some sort of a cover on your interior pot to keep the steam out. I've used Weck jars for yogurt-making and simply set their flat glass top on them to keep out contaminants out. Works great!
<p>This looks like a fun session for making bread. Thank you for posting this. I think i am going to try it :)</p>
<p>heh, as far asa the &quot;mod&quot; goes.. youve completely missed the point of a SLOW cooker.. its not supposed to &quot;get hotter, cook faster&quot; or &quot;be more efficient&quot; its supposed to cook things SLOWLY so they tenderize, and also so it can be left on while your at work :) As youve noted with your melted handles, that last, especially is a VERY bad idea with a modified appliance, especially one sitting in a card board box hehe. My advice? Buy an oven, and leave the slow cooker alone!</p>
can you leave out the salt?
I don't know WHY you would want to leave out the salt. Bread really needs a little salt. Without it, the bread tastes very bland.<br><br>You can certainly try it, and see how you like it. I accidentally forgot the salt once, and was very disappointed in that particular loaf, while my sister thought it was fine.
When you insulate the Crock Pot--not to the point of burning the house down please!!!--You are basically making an Olde Tyme Hay Cooker. These are still used and consist of a box stuffed with some sort of insulating material--hay or shredded paper or what have you--and in inner container containing the HEATED FOOD to be finished cooked. The heating gets everything started and of course doesn't take that long. Then you pop the food container==covered with a tight fitting lid or foil and a lid--into the middle resting on the insulation and cover with more insulation and you CAN wander off and come back a few hours later and the food is all hot and cooked. <br> <br>There are other versions of this called Sous Vide which will cost you a bundle at a fancy restaurant but can be done at HOME on the cheap using a PICNIC COOLER and some ZIPLOCK BAGS. Again you will need to heat SOMETHING--in this case WATER--but you then immerse your bags or sealed vac-bags and cover with heated water--not sure if it has to be boiling when added or not--and wander off and take a nap and come back for dinner--gently cooked food AND hot bread if you are clever and time it right! <br> <br>Somewhere out here in cyber space is a STEAK RECIPE cooked this way that I am longing to try one day. Allegedly the BEST steak. We shall see!
Yep, there's a lot of cool semi-scientificy ways of cooking food! &quot;Bean-Holes&quot; are another good one!<br> <br> You can also cook steel cut oats overnight in a thermos.<br> <a href="http://ecoprojecteer.net/2012/07/thermos-oats/" rel="nofollow">http://ecoprojecteer.net/2012/07/thermos-oats/<br> <br> &nbsp;</a>&nbsp;I haven't tried sous Vide yet, but I HAVE made yogurt in a Scientific Water Bath!&nbsp;
This is really cool ... do you think it would work as well in a crockpot that doesn't have a stoneware liner?<br> <br> I have a <a href="http://www.walmart.com/ip/GE-6-Quart-Digital-Slow-Cooker/12442589" rel="nofollow">GE crockpot</a> that has a nonstick metal liner (I was less than pleased when i found out that fact .. but the wife says she likes it so we kept it.&nbsp; Personally I miss my old rival but I haven't found a replacement stoneware for the one that broke.)<br> <br> I am so glad I'm not the only one that uses the laser thermometer in the kitchen ... SEE HUNNY, I TOLD YOU I WASN'T WIERD .. lol<br>
I wouldn't try directly baking bread in there. I've never been a big fan of teflon and &quot;non-stick&quot;.<br><br>Try the double-boiler method. I bet that would work fine for you.<br><br>Instant read thermometers are great! Everyone should have one in the kitchen!
I was just wishing I had one a couple of days ago (non-contact thermometer) to check the temp in my skillet! I may have to figure out a way to add that to the tool arsenal...
they are actually alot more reasonably priced than you would expect. typically they are around 30- 35 dollars .. but if you are patient you can occasionally find them on sale for as little as 10 or 15 bucks.
I've seen them at Harbor Freight for a while now and never picked one up. That may need to happen sooner than later.
Wait for the coupon! Harbor Freight has great coupons. I got my laser thermometer at less than half what their regular price was. Totally worth it.
Sweet! I think I've heard of crock pot bread, but have never actually seen it! Looks delicious :D
AWESOME!!! I'll have to try and make some....Thank you for sharing; great story too. : )
About This Instructable
131,612views
284favorites
License:
Bio: Ordinary guy with no special skills, just trying to change the world one backyard invention at a time. See more at: http://300mpg.org/ On ... More »
More by bennelson:Medieval Coloring Book Princess Castle Bunk-Bed Wet & Underwater Product Photography
Add instructable to:
