Crock Pot Mason Jar Oatmeal
1,270
28
7
Posted
Introduction: Crock Pot Mason Jar Oatmeal
I like the idea for cooking oatmeal overnight in a crock pot, but the cleanup is a pain and sometimes I don't get it cleaned in time to use the following morning. I wanted to avoid the use of plastic bag liners because that is just wasteful and generates unnecessary garbage. I was looking up prices for additional ceramic inserts, and saw in one Amazon review that a person was using ramekins double boiler style to speed up his clean-up.
That is when I wondered how a similar setup with mason jars would work. The results were better than I hoped.
Step 1: Parts and Ingredients
1 small crock pot (mine is a 5-cup pot)
1 pint mason jar
1 bowl that fits on top of crock pot
oatmeal mix:
1/2 cup oatmeal
1 cup water (you may have to experiment with more or less depending on how you like your oatmeal consistency)
dried fruit
honey/sugar to taste
Step 2: Setting It All Up
1) Place your oatmeal mix in the mason jar. Make sure you give it a quick stir.
2) Place the mason jar in the crock pot
3) Fill up the area surrounding the mason jar in the crock pot with water.
Step 3: Cover It
This may not be an issue with larger crock pots, but the mason jar was slightly too tall for mine. Luckily, one of my bowls fit perfectly
Step 4:
Plug in the Crock pot when you go to bed.
8 hours later, when you wake up, the oatmeal will be perfectly cooked.
Use an oven mitt when you take out the mason jar. It will be hot!
You can dump it in a bowl and eat it immediately, or you can put a lid on the jar and take it on the road.
When I was cooking the oatmeal in only the crock pot, sometime the oatmeal would really stick to the bottom or even burn onto the ceramic insert. This made the cleanup really difficult. So far with the mason jars, that has not been a problem. Instead, I just fill the jar to let it soak for a few minutes, give it a good shake, and anything that was sticking pours right out.
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    7 Comments
    Looks yummy! Did you use old fashioned oats or quick oats?
    I used old fashioned to test it for you, and it worked just fine, it isn't as "mushy"(that isn't the word that I meant to use but I couldn't think of the right one) it has more texture to it.
    I only had the quick cook on hand, but it should work for old fashioned as well.
    Sounds good! Wondering if having water surrounding the mason jar would make any difference? Might help distribute heat better?
    I am soooooooo gonna try this tonight! !! Love your idea!
    My crock pot has two temperatures, hi/low. Which do you use?
    My Crock Pot only has one setting, but I believe the Low setting is what you'd use.
