Cross Cutting Sleigh
Published
Introduction: Cross Cutting Sleigh
About: They Call me Wallace.
Fellow Instructables here i have a Cross Cutting Sleigh
if you have a table saw this is a must. it will make cutting Small Pcs of wood very Easy and Safe.
i use 20" by 30" by 1/4 inch thick Not Flexible Wood
for the Fence 30" by 6" by 1/2" i use Pine.
the middle of the Sleigh must be off centre to the blade. in my case
the L side is 13 inches and the R side is 17 inches.
install the Rails on the bottom of the sleigh
They must fit nice and secure inside the channels but not touching the bottom.
place a small pc of cardboard inside the channels place the Rails in side put Glue on top. all the way along Each Rail
then pace the wood on top and place something heavy until glue sets
Flip wood over remove cardboard from channels " the two channels on the table saw"
move wood forwards and backwards it must ride freely and easy.
after making sure the table saw blade is an a 90 degrees angle to the table
secure the front & BackFence to wood. make sure front Fence is Square to Table Blade.
move wood away from blade . raise blade 1 inch and make your Cut all the way from back of fence to front of fence.
Raise Blade all the way up and Cut one more time. Fence Must be taller than Blade
For Safety Make a Box and place it in front of the Fence The one thats closer to you.
so that the blade is always away from your hands.
Now go and make something.
Step 1:
Step 2:
Step 3:
Step 4:
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    5 Comments
    The 1st picture you see its the finnish product. and it works great hope you make one
    Sorry, I should have been more clear... I would like to see the instructable completed.
