loading
Step 5: Putting it all together
Final step, putting it all together. Make sure you are careful, misstakes now will be harder to correct.
I'm sorry i dont have any pictures of the arrows. They are like ordinary bowarrows but shorter, usually the lenth between the bow and the hooked string. The end should not have the usual notch but should be flat on two sides so it fits between the two flat bars on the lock.
I wish you happy and injury-free building and shooting!
<p>Hi I failed to make this miserably, I was wondering if you would sell it me with three arrows it would be a great present </p>
How does this kind of trigger mechanism work? I have made sketchups of rolling nut triggers and this kind is a first for me. :)
<p>Did you just make this part yourself? Is it aluminum?</p>
u left out like half the info I need
I don't mean to be rude but it's a kind of failsafe - when you are old enough to read an instruction and figure out the not so obvious parts you are old enough to use a crossbow. Be patient. ;)
I can't see how exactly you attach the enforcement loop, though I'm sure the site won't appreciate posting copyrighted materials, but could you maybe explain it in a bit more detail?
<p>Sorry for a very late reply.<br>I found parts the book scanned on: </p><p>http://howtomakearmour.blogspot.se/2013/08/making-medieval-crossbow.html</p><p>This picture maybe explains how the string are made:</p><p><a href="http://4.bp.blogspot.com/-RjfiJX56tBU/Ug9g9dLT_KI/AAAAAAAABUY/6-LJIyrmzk0/s1600/21+fig66.jpg" rel="nofollow">http://4.bp.blogspot.com/-RjfiJX56tBU/Ug9g9dLT_KI/...</a></p>
<p>No worries, and thanks for the links. </p>
Wow how long did it take you build this? Also how much money did you spend on parts?
It was a few years cinse i built it but most oft the parts was stuff i had laying around. The rattan part was 2 meters long and i think it costed aprox. 10&euro;. The stock was made from a larger piece of ash that i gotten from i friend, the metal part was free but the box of spring costed maybe 15&euro;. <br>Im unsure about the time it took but if i made it today it would be two days of actual work, its hard to say. The rawhide and glue has to dry and so on s&aring; its a lot of time spent waiting. Best way to find out is to start building ;)
har du nogle billeder af boltene den skyder med? <br>Det ser ud til den er over 10 &aring;r gammel nu, hvordan holder den? Kan den stadig skyde? <br> <br>Jeg under mig over at der ikke skal v&aelig;re en form for rille p&aring; toppen for at holde bolten p&aring; rette kurs. <br>/Thomas
Armborstet &auml;r tyv&auml;rr inte kvar i min &auml;go men senast jag h&ouml;rde av &auml;garen s&aring; fungerade den gott. Har tyv&auml;rr inga bilder p&aring; bultarna, dom var ca 30-35 cm l&aring;nga och 8-10mm tjocka. <br> <br>P&aring; de &auml;ldre, fr&auml;mst 14-1500-tal, armborst som jag har sett s&aring; har jag aldrig sett n&aring;gon r&auml;nna. Tror att det &auml;r viktigare att b&aring;gen drar rakt. <br> <br> <br>Tack f&ouml;r din krympburksinstruktion, har anv&auml;nt den i min undervisning!
This is probably the best crossbow instructable on the site. The bow you made loos amazing, and I really like how sophisticated you made the stock, with a trigger and everything. I'm not so sure about using rattan as a material though. At my karate class some of the teachers have staffs made of rattan, and I know that if they take enough abuse, they can shatter.<br />
Thank you!<br /> Everything will sooner o later shatter.. I guess that the difference is that your karateteachers were hitting the rattan instead of just bending it. Just lika metal wood vill bend to a certain point and then start to deform och break. Bu using a quite long bow the bending per cm (or inch) gets less than with a shorter bow.<br /> The rawhide in front of the bow will make the break less dangerous. Usually the wood vill loose some strenght instead of break when old.<br /> <br /> (and without a stock and lock it would just be a bow ;) A stock with a stiff bow and som rubberband is a slingshot, not a crossbow. There seems to be a lot of confusion.)<br />
I used to fight in the SCA society of creative anachronism. We used rattan for our swords for when they eventually break they break without sending shards into someones face, so rattan is actually a good choice from a safety point of view
I actually got the rattan from my SCA-friends, their use of it as svords, poleaxes and bows inspired me to try it on my crossbow. <br> <br>By they way - i saw that almost 25 thousand people has seen my 'ible. Thats insane. Don't you have anything important to do? ;)
&nbsp;What if the slingshot (under your definition) has a mechanical trigger?
Then it would be a very obscure and cool invention they used to call the &quot;slurbow&quot; it was a crossbow with a barrel for slinging lead balls to kill small game. <br>
And they just /had/ to pack gunpowder in there
nice finished project! im thinking about making one of these, but im probably going to use a different kind of bow for a budget. i probably will stray from the design a lot, but i never could figure out how to make a lock, so i never pursued this project. now i know how i could make one ;)
Couldnt u use a crossbiw string for the string? <br>
How do you mean, a crossbow string? The one i use is a quite typical crossbowstring.
Were did you get the trigger I want to make this for a costume for Rennaciase fairs already hayve the chain maile thanks<br><br> -Kid
Hi. The trigger was made from 12x12mm iron bar. Welded together and shaped with a hacksaw and filed to proper shape. Try and ask your friends /parents and see if someone can help you make one.
is there any other types wood that would be sutable for the bow <br>because i cant find ratan <br>
nice crossbow crazycreator187, looks nice, i think ill make one like yours! how gooda accuracy and range does it have? <br>
wy not? looks pretty biesty
thanks, the accuracy depends on how straight your bolts(arrows) are and what sort of fletchings are on them. As fro the range that also depends on the bolts but if you shoot it straight up the bolt goes out of sight and stays in the air for 10-15 seconds. as I said further up, if you want me to I could probably take the crossbow to pieces (none of it is glued) and make an instructable.
I have just finished a crossbow, it uses a <a href="http://www.pyramydair.com/blog/images/10_11_07_crossbow_trigger.jpg">roller nut trigger</a>, has a pine stock with 25 by 25mm square tubing, the bow is made out of a leaf spring.
That is a great looking job,I'd love to have designs for that.
I could probably take it all apart and make an instructable if you want, It would be more of a guide than step by step instructions.
It looks really nice! <br>How heavy are the bow?
do you mean weight or pull back weight?
kool invention i want oooooone
A bit big for opening bottles. Not really the right shape either.
Have you tried? :)<br> Sometimes you'll just take the first hard thing thats closest to you. I consider it a useful skill to open a bottle with anything laying around.<br>
&nbsp;Now this is what you call a vintage crossbow! or real crossbow... ah whatever, I'll just say this: This is the sum of all DIY Technology ever developed in the 21st century!
wouldn't you need a slot across the top of the stock for the fletches on the bolt to run in? nice crossbow
Thanks! And no, the bolt has only two fletches so its no problem.
not true i have 2 and they both have a track&nbsp;
There are many different ways to solve this problem, since this was a crossbow that was supposed to have some historical feeling to it and most historical crossbows i have seen had two fletches i choosed that solution.<br /> <br /> <br /> Thanks!<br />
ok both of mine are from the 60s and later&nbsp;
but still nice job<br /> &nbsp;
where do you get the rattan<br />
Hi!<br /> <br /> I got the rattan from a German man i met at a SCA-event in southern sweden. If you google you might find something more near you.<br />
Needs more work. No, not the crossbow - the instructable. It needs more writing, and some more info like how to build your own trigger assembly or where to get a premade one.
This is a ible' about how i made this particular crossbow, they can be made in hundreds of ways. If i should cover all the ways a crossbow trigger may be built it's better to make a whole new ible'. Considering how long it took to get this one approved and how much spare time i have at the moment it will take a while... If your in a hurry to know more just google and i promise you'll find something useful. I admit that the text is a bit short, will try to write more when i have some spare time.
if i met you ied shake your hand, you have just summed up what ive been looking since i first found instructables well done
Oh, i'm very happy to hear that! :D I did a lot of research and hope to save some of that work for others. Even tho the Payne-Gallwey is incredible to read, written in 1903 by a English lord who obviously had to much time and money on his hands...
About This Instructable
71,486views
481favorites
Bio: Working as a wood/metal shop teacher for kids 9-12 years old. Restoring a old house and a Saab 95 V4 1975. Currently bad at ... More »
More by Vidar_76:Carrier for IKEA Korken bottle Simple outdoor lamppost Some thoughts about making kitchen interior
Add instructable to:
