3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Crossed IR Beam Camera/Flash Trigger
Step 3Mechanical Construction
I initially tried to make this thing with a 3 foot square of 1/2" pipe but found it was nearly impossible to keep the beams aligned. The distance was too great and the pipe too flexible to maintain beam alignment. I switched to 3/4" pipe and a 2 foot square and now it all stays aligned pretty well. I used most of the 1/2" pipe to make marshmallow blow-guns for my son, Alex, and some of his hoodlum friends.
You will need 3/4" pipe for the main frame and 1/2" pipe for the vertical risers that house the optical ICs and LEDs. You can get 3/4" elbows that have a 1/2" threaded side connection, so get some 1/2" thread adapters too.
My philosophy about dealing with PVC pipe projects is to over-buy the fittings and pipe and return what you don't need when the project is done. That minimizes frustrating trips to the store for a single $0.30 fitting.
You will need a bunch of different colored wire to connect all this stuff- the LEDs and their ICs are separated by about 6 feet of pipe. You will want to make the wires extra long to allow assembly and taking the thing apart for troubleshooting. Different colors will help you keep straight what connects to what.
The first thing I did was drill holes in the caps and mount the LEDs. I attached extra long wires and used heat-shrink at the LED leads to insulate them. I loosely assembled the pipe frame so I could pull it apart easily and ran the wires through the pipe.
Next, mount the IS471 chips and caps on perf board cut to fit into the opening in the end-caps. Drill a hole in the cap and install a piece of 1/4" brass tubing (or whatever you have around). Be sure you know which side of the IS471 is the receiver side! You want it to face your LED, not the bypass cap! Attach wires to the IC board- there will be a total of five connections- Vcc, Gnd, Out, and LED. The fifth wire connects the anode of the LED to Vcc. Decide where you want to put the connector on the pipe frame and make sure the leads to the IC are long enough to reach it.
Mount the connector, run the wires, solder it all together and you're ready to go. Don't forget to solder a ground wire to the shell of the connector. It will help protect everything from static electricity.
Once all the wiring is done, pound the pipe together tightly with a mallet. You should not need glue, and if you glue the pipe together you'll be unable to take it apart to fix problems later. If you want more secure construction, drive a screw through each joint after pounding them together.
When the controller is assembled you will have to align the beams. The relay will close only when BOTH IR beams are interrupted/misaligned. The outputs of the OPICs are normally low, when they can see their light source and go high when the beam is interrupted. So aligning the beams is done as follows:
1) Connect the optical frame to the controller.
2) Power on. The LED will light and stay lit unless you are extraordinarily lucky. First it lights to indicate continuous mode, then it stays lit because the beams are out of alignment. If the LED goes out it means at least one beam is aligned.
3) Assuming that the LED is lit, it indicates that both beams are misaligned. Block one beam with a piece of tape or paper.
4) Align the LED as well as you can by twisting the head to point it toward the diagonally opposite OPIC.
5) Now start flexing and twisting the OPIC head until the LED goes out, indicating that the beam is aligned.
6) Next block the freshly aligned beam, then make the same adjustments to the second beam. When the LED goes out, both beams are aligned and you're ready to take some pictures.
Whenever you power the unit up, check the beams by blocking one then the other. If one beam is misaligned, blocking the other will cause the LED to light. Then you can just realign the one that is out of whack. If the LED lights and stays lit, both beams are out of alignment and you need to follow the procedure detailed above. If you build the thing securely and align the beams for the first time it will take some punishment before you have to do any realignments.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:Mark Rehorst(Mark Rehorst's Projects Page)
I was electrical engineer for 22+ years, then went back to school and became a dentist.
