Crossover Dongle
Crossover Dongle
If you're like me you've got a bah-jillion cables floating around in your computer bag. I got tired of having to have two separate types of cat-5 cables, straight and crossover, so I came up with this little gadget that will turn any straight cable into a crossover cable.
Step 1Parts
Parts
Here's all the tools/parts you will need:
1 x RJ45 Crimp Tool
1 x Push Down Tool (some keystone jacks come with their own)
1 x Wire Strippers
1 x Cat-5 Cable
1 x Cat-5 End
1 x Keystone Jack
1 x Hand with at least one finger and opposable thumb
42 comments
1-40 of 42next »
Dec 26, 2011. 11:36 AMfestec says:
that type of cross cable over has been around for years ! if you need one for giga bit then you cross over the blue and the brown pair... I have been making them for years. here is a picture of one in the internet archives back in 2001
you might have to cut and paste the link
http://web.archive.org/web/20010224082835/http://www.directconnect.bizland.com/cables.htm
Jan 15, 2012. 11:02 AMfestec says:
Jay Stapleton in Thunder Bay phoned me back in 1999 asked if I could make him one ....I think he is the first to come up with that type of cross over cable !
Way to go Jay
Jun 3, 2011. 3:06 AMMojo_JoJo says:
I made mine like this, it accepts two straight cables and crosses them. I find this easier to carry in a laptop bag. It originally had two female connectors connected in stright through configuration, it was pretty easy to open and cross the pins of the socket. HTH
Jul 10, 2007. 1:22 PMtsedlmeyer says:
Great instructable; however, there is one problem with the cable produced.
Unfortunately this cable will not work properly for gigabit ethernet. Gigabit Ethernet utilizes all four pair on the cable. The cable presented here only crosses two of the pair. The correct pinout can be found here. Unfortunately most commercial crossover cables are also not correctly pinned for gigabit ethernet use.
If you use one of these incorrect cables you will still get connectivity on a gigabit ethernet interface; however, you will only get 500Mbs instead of 1000Mbs.
Jul 26, 2010. 7:19 PMshortw says:
If I use the the 1000 T base crossover, will this work with 568 A and 568 B system?
Jul 14, 2007. 6:34 PMjmumby says:
Gigabit internet does not need a crossover anyway. You can plug any normal network cable and it will just work!
Jul 15, 2007. 9:04 AMtsedlmeyer says:
The spec does not require NICs to detect whether they need to internally cross. Most gigabit ethernet NICs along with many newer fast ethernet NICs do and indeed do not need a crossover cable. Some NICs do not and some disable this feature if you manually set the speed and duplex. Many people manually set speed and duplex for connections such as switch to switch or firewall to router.
Jul 10, 2007. 1:38 PMtsedlmeyer says:
I should have said may give you connectivity up to 500Mbs. Some chipsets will use the two pair to give you 500Mbs. For instance if you connect two Cisco switches they will do so. Some NIC's will fall back to 100Mbs and some may not provide a connection.
May 18, 2009. 10:33 PMmaxstevenson says:
of course! so logical... this should be a standard tool. Is your name Spock, by chance?
Jul 20, 2010. 1:59 AMhintss says:
or the doctor or Data or teh interwebz
Apr 19, 2010. 5:27 AMva1cho says:
ethernetcablewiring.com/ethernet-crossover-adapter
I think this tool is better choice because you need to do nothing and price is cheap.
Jul 8, 2010. 11:09 AMRedgerr says:
i agree with you GitarGr8, the thinkgeek one is superior however that takes all the fun out of it.. buying stuff isnt allways the best way!
Aug 22, 2007. 9:52 PMPasit says:
i wasnt trying to be critical it was supposed to be a question?? and wtf's the difference between a stait cat5 cable and a crossover cable, and whats a cat 5 cable?
Feb 28, 2010. 1:27 PMrahulait says:
to be more precise, a cat5 cable is having 5 twists per 1 inch of the cable. its a standard... similar to this we have cat3 cables, cat4,cat6 cables....
Nov 6, 2007. 11:26 AMsrmousse says:
cat 5 cable is the proper term for the most commonly used network cable (the thing that plugs from your internet router to your computer... similar to a phone cord but with more pins). The purpose of a crossover cable is to eliminate the need for a network hub (a device used to network several computers together) when connecting two computers together (or even xbox's for that matter). Basically the crossover cable crosses 4 of the wires so that the two computers (xbox's) can talk to each other.
Nov 19, 2009. 2:10 PMDraakUSA says:
With newer equipment you almost never need this, since most new equipment will auto-detect.  However, this is handy to have for equipment that doesn't.  I've had one in my toolbox for several years that I use when I need it.
Aug 22, 2007. 9:40 PMPasit says:
i dont get the point of this instructable, u just turned one "outy" end into and "inny" end. so the "outy" end of the other cable that would be plugging into the orange "inny", couldnt it just go strait into the port on the computer istead of through that thing??
Mar 12, 2008. 2:21 PMstatic says:
Respectfully, you where a bit sensitive that day, as I noted no criticism.
Mar 12, 2008. 2:00 PMstatic says:
I had the local network guy make me one of these several years ago. I didn't have the tools nor the cable. I dont know if RS carried them or not. but RS is 50 mile round trip for me if the do. Having the local make me one kept money in my pocket. Good instructable
Feb 24, 2008. 9:03 AMRandy Lahey says:
Wow, this is crazy. I made one of these a few years ago when i used to be a computer tech. Very handy. When i made mine I thought to myself "Holy Fuck! what a great idea! I wonder if anyone else thought of this?" It's definitely a must-have for any computer/network techs out there. I'm suprised you can't buy these. p.s. It will also turn a crossover cable into a straight cable.
Mar 7, 2008. 3:40 PMn0ukf says:
But the point of Instructables is DIY and share how you did it. In some cases it's cheaper to buy, in others it's cheaper to make, and in yet other cases, the project isn't available for sale anywhere.
Feb 4, 2008. 7:04 PMmaker12 says:
nifty!
Aug 21, 2007. 7:59 PMvaiden says:
Man, this is a great instructable. Just the other day I had to cut a damn cat5 cable and swap the tx and rx wires to hook two routers together. Im gonna make one of these bad boys. I dont have gigabit nics, so even though I have a gigabit switch ,I can hum right along without both pairs. Great idea!
Jul 16, 2007. 3:26 PMThe Lightning Stalker says:
I don't think the keystone jack grabs onto the outer sheath of the cable. This presents a strain relief problem. It might be a good idea to roughen up the sheath near the keystone jack with some sandpaper and dab some flexible drying epoxy around to bond it with the keystone jack. This comes at a loss of the ability to rewire the jack, but should make a more reliable connection since keystone jacks are intended for racks where the wires won't be flexed often.
Jul 14, 2007. 11:00 PMWolver says:
Now why didn't I think of that? Nachos Bellgrande props to Gitar
Jul 14, 2007. 9:24 PMrimar2000 says:
Very useful. Good idea, expandable to other applications.
Jul 14, 2007. 4:13 PMqpmarl says:
I made one a thems once. Still have it. Never actually used it though. I'm all wireless these days.
Jul 14, 2007. 2:03 PMSpokehedz says:
Most punch-down tools have a second end that you use by flipping around the connector. The ends are double-ended as it were.
Also, you can get a retractable CAT-5 cable that will spool up the cable into a neat little box. very handy, and keeps the box nice and neat.
http://tinyurl.com/2ra2wh - Example of retractable cat-5e cable
Jul 9, 2007. 8:46 PMbenjgvps says:
Now if only my Powerbook 150 had ethernet..
Jul 9, 2007. 7:40 AMmrmath says:
You get geek points for carrying a straight to crossover converter. I've seen them for sale commercially, but your version offers two advantage. First, the ones I've seen have to have two cables plugged into them, one on each side, so you still need two network cables. Second, you get extra geek points for having made it yourself.
Jul 9, 2007. 11:36 AMJakeTobak says:
The one I bought didn't require 2 cables, but it didn't have any slack like this one does. It was very hard to unplug because of that.
Here's the one I have/had (I don't know where it is)
http://www.thinkgeek.com/gadgets/tools/7ef8/
Jul 9, 2007. 10:22 AMJezza Bear says:
Great Instructable, one of those projects I have never ventured to do, this is certainly a good reference.
Jul 9, 2007. 4:57 AMfarker1 says:
I have another 2 ways to do this to be used in a 'lightweight' tool kit 1. make a short rj45 plug to plug crossover cable and then use a rj45 socket to socket adapter to join to a straight through cable. The socket adapter can also be used with 2 normal cables to make an extended cable if needed and also rj11 cables to extend modem/router cables 2. buy a socket to socket crossover adapter to be used with 2 normal cables or you can make one with a normal adapter.
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:GitarGr8
I'm a controls engineer (geek), who enjoys long walks along a moonlit beach.
