3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Crude Tracking Device from a GPS And Two-Way Radios
So, I wanted to get a tracking device. As soon as I looked into the market, I realized the prices for one of those things begins at an arm, and goes up to a leg or more! The madness must be stopped! Surely the principles of knowing where something is could be used without paying out the nose for it. After some hair pulling, this idea was born. This took a lot of trial and error before I was able to hammer out what it has become for me today, and for all that, it is just workable enough for my purposes. Therefore, if you can think of a way this concept could be made better, please share! I've built on the shoulders of giants, and I expect you to do the same. This idea belongs to the people! Information is free! Insert an inspiring slogan here!
The nature of this tracking device is extremely limited and technical, but if you can hack it, this really works -- and that in itself is really exciting. The limitations are at times frustrating:
  • The 2-way radios necessitate a linear or nearly linear sight on your tracking device (which in many cases may spoil the whole point anyway).
  • You must be closer to the transmitter than the nominal range of your radios.
  • The tracker can get bulky (think about it -- you're basically lashing together two electronic devices that were originally meant to work separately).
  • This one is the worst limitation: you will need to be able to manually sift through the static garbage that radios usually emit to find the data your GPS is trying to send. If you are a total 1337 h4ck3r, you may be able to write a program that pulls it out automatically and feeds it into Google Earth. (If, incidentally, you do accomplish this, tell me what to do to gain your favor when you take over the world.) Beware! Radio static can get really random, and will even imitate the data you are after, often giving you misleading results.
So far, for all my test runs, this device has about a 60 percent accuracy. Yikes.
To quote, with a slight change, someone who inspired me to think this way: "If you can't modify it, you don't own it!"
Building on that, the lesson I have learned and hope to teach others is that something's label should not limit the way we use it.
Step 1Gather Supplies, Tools, and Materials
Get a GPS that you can plug into a computer. I used a Garmin GPS 72. I am of the opinion that Garmins are the best and most reliable, as well as the easiest to hack. If you insist on using a different kind, be prepared to figure out the I/O stuff yourself. At any rate, I suppose this project is possible with any sort of GPS unit, provided it can send info at a low baud rate.
Get a cable that connects the GPS to a computer. For my project, I used a COM port plug, since I already had it lying around, but I suspect using a USB connector would have been slightly easier.
Get a pair of walkie-talkies (Americanese for 2-way radios) that have an impressive range. For this example, I am using a pair that boasts a 12-mile range.
Other materials included in this project: Wire, solder, batteries, a computer, and glue or epoxy. Optional: something to track.
Tools you will use include: wire cutters, wire strippers, screwdrivers, pliers, a soldering iron, a DMM (Digital Multi-Meter), scissors, an undefiled radio, and the user manual of your GPS.
Find a quiet, peaceful place to fine-tune this. Several of the steps are bound to be frustrating for a first-timer, as they were to me.
31 comments
Jun 8, 2011. 11:41 PMpbates123 says:
It never ceases to amaze me when I read something like this. The fact that you managed to get anything out of this just blows me away. But Cudo's to you! Wow!
You could improve your transmission rate immensely by placing a couple simple intermediary devices in the circuit. Your radio's are meant to transmit audio not pulses like come out of the GPS and go into the computer. It is shear luck that the computer interprets the spikes/clicks coming from the receiver to the computer. There are a couple of replies that point to the Automatic Packet reporting system which would work and solve a lot of your problems.
This is best way to implement your solution, not using cell phones. Use Dual Tone Multiple Frequency transmission (DTMF) it marries the Serial Digital Data from the GPS to the analog audio transmitted and received and converts it back to Digital to interface to the computer. Follow the links to a device, one of many, that perform this task.
http://www.cmlmicro.com/Products/index.asp?/Products/WTelecom/CMX865A.htm&searchvalue=wlt&setindex=1&gclid=CMa965GWqKkCFcsZQgodvCDpLg
God bless Yankee ingenuity !!!
Jan 22, 2011. 1:09 PMXellers says:
This is nice, but it's much easier and cheaper to use an inexpensive ($30) pay as you go phone and then install a java applet that will transmit the location of the phone at a regular interval....
Feb 18, 2010. 2:12 PMB.F.L.M says:
This is all really interesting. Great job! If you hook-up the recieving speaker to another microphone (w/good quality) and connect that to another gps with a built-in map (after disabling THAT gps' 'location data stream') so that it would use the other gps' coordinates to map it out so you dont need google earth? What if you brodcasted the signals via AM frequency (is that illegal?). Please let me know
                  thanks>
Jan 23, 2010. 10:17 PMyusuf786 says:
Hey Dude This Is So Cool...! Well I Was Thinking To Make One Like This. Hey Is There Any Other Way Which Is Much Easier & Cheaper To Make A Tracking Device...? If Yes Please Let Me Know. I Also Would Like To Know If I Can Make An Device That Would Tell Me Where The Object Is...? Im Not Sure How To Explain...Anyway Great Tutorial...!!!!
Jan 26, 2010. 5:34 AMyusuf786 says:
Hmm...Okies Hope That You Make More GadGets...! Im WaiTing hehe
Nov 5, 2009. 1:46 AMangervent says:
This is insane man. Great job,  I can totally see the steam punk set up.  Or maybe a modern movie/tv with the "hacker kid " who whips this up in 30 seconds. Anyway,  I got a couple spare walkie-talkies, any other Brilliant ideas?
Oct 2, 2009. 6:23 PMdanielemur says:
Great instructable! rather than using the walkie-talkies to transmit gps data could you use them to send video?
Oct 17, 2009. 5:30 AMKryptonite says:
Pics or it didn't happen. :D
Sep 6, 2009. 2:00 PMfrasierman says:
Wait... can't you use an old cell phone... or am I just stupid?
Jul 23, 2009. 8:38 AMve3bow says:
Ham radio operators have developed a very nice system for this, and you will find lots great project ideas too.
It is called the Automatic Packet Reporting System
http://aprs.org/
Sep 5, 2009. 1:06 PMmcastles says:
I gave you a five cause I think yours is much more complex than mine, to fathom an idea like this would definitely use some good thought. : )
Jul 29, 2009. 2:58 AMdchurch24 says:
How do you transmit the location? I was thinking of doing a similar thing and using an Arduino to translate the lon/lat to morse - that way I could get further away and still interperete the break in static.
Jul 30, 2009. 6:12 PMve3bow says:
This explains it well
<http://en.wikipedia.org/wiki/Automatic_Packet_Reporting_System#Technical_Information>
In its most widely used form, APRS is transported over the AX.25 protocol using 1200 baud Bell 202 audio frequency-shift keying(AFSK) on frequencies located within the amateur 2-meter band.
David
May 10, 2009. 9:05 PMltkenbo says:
Just a idea, but wouldn't a more interference free way to do this be to use a cell phone? Maybe have one where when you call it would answer so you could call it and check the location.
Jun 25, 2009. 7:48 PMtannerr52 says:
mologogo...put a cheapo prepaid phone in a box (with mologogo)...under a car...
Mar 6, 2009. 6:02 AMNojiRatz says:
You make me proud, V-Man
Feb 24, 2009. 5:29 PMipodgeek says:
Interesting tracking system you made there. You did a good job and it looks like you did a good bit of work to get this thing to work. Quick question, can the program Earth Bridge track cellphone numbers and tell you where you are located?
Feb 24, 2009. 5:02 PMbernard192 says:
Very good idea, although like you said, it will be limited by the range of the walkies. But definitely a very interesting concept. Quick question though, do you think it would work if you got a headset to plug into the transmitter, cut off the plug part of it, and solder the wires to that? That way, the transmitter won't be permanently deformed. Or would there be too much noise, or voltage? Just a thought.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:V-Man737
I'll cut and paste stuff here as time goes on.
