Crude WiFi-Enabled Weather Station
2,260
35
Posted in TechnologyArduino
Introduction: Crude WiFi-Enabled Weather Station
About: Student, currently studying programming. Interested in Arduino, Raspberry Pi and Electronics in general.
Today you are going to learn how you can build a simple WiFi-enabled weather station that sends you the temperature and humidity data using IFTTT directly to your e-mail. The parts that I've used can be found on kumantech.com
Step 1: Parts Needed & the Necessary Conections
To complete this project, you will need:
Allchips is an electronics components online service platform, you can buy all the components from them.
How do I connect the sensor to the board?
DHT11 | NodeMCU
GND (-) -> GND
5V (+) -> 3.3V
OUT (Signal) -> D5
Step 2: Setting Up IFTTT
Head over to IFTTT.com and register an account (if you haven't already). After that, go to My Applets and then click on New Applet. Then, click on + this and when asked to choose a service, select, Webhooks. A list of triggers will popup, and at the time of writing this, there is only one available option - Receive a web request. Next, choose a name for the event and remember it (it will be used in the code). After creating the trigger, you need to click n +that and choose the service that we are going to use. In this case, it is email. In the next page, you need to choose how is the email going to look like. This is entirely up to you, but remember, you need to include the Value1 and Value2 fields for the incoming data. For reference, take a look at the third screenshot above. One last thing, go to the settings of the Webhooks serviceand at the bottom you will see an url. Copy the string after use/ and save it somewhere. This is your unique API key, you will need it later in the code. After completing this step, you are done with IFTTT for now. It's time for the code for the NodeMCU
Step 3: Uploading the Code and Customizing
Before uploading the code (which can be found here), take your time and look at the commented lines and variables in the begging. You need to change some things up, and then upload the code to the NodeMCU.
After uploading the code and powering up the board, you will receive emails every x amount of time (can be modified in the code above). If you have the IFTTT app on your smartphone, you can receive notifications every time the applet runs. Now, check your email and you will see the weather data. You can add more sensors and connect with other applets.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    1 Questions
    I am a Newbie and would like to place several of these devices throughout my greenhouse to measure temperature and humidity fluctuations. Could I use multiple devices, and how do I physically upload the code to the NodeMCU?
    Thank you for your time, Carter
    Yes, you can. But then you will need more power supplies and it becomes a bit impractical. In order to upload the code, you will need to plug in a Micro-USB cable and use the Arduino software with the NodeMCU settings while uploading. Good luck!
    2 Comments
    teria uma imagem da estação de trabalho
    It's just a simple concept atm, currently working on improving it
