Crushed Can experiment!
 by Miro95
This is a cool experiment that i demonstrated to my classmates : what happens is that ...........................
A small amount of water is heated in a soda can until steaming. The can is then quickly put in cool water, mouth side down. The sudden change in temp causes a sudden change in pressure, making atmospheric pressure higher than the can pressure. Thus, the can collapses under the pressure.
Materials:
1. Any soda can
2. oven or Bunsen burner
3. beaker ( 250 ml - 500 ml)
4. room temperature
5. tongs
P.S : this is my first instructable so please rate it!
Step 1: Getting started!
first get your beaker and fill it all the way to the top ( see first picture) - a glass cup could work too!
Then fill ur can with enough water to fill the bottom ( see second picture)
SomeKidsAtSchool says: Mar 4, 2013. 5:24 PM
What happens if you put pickle juice in the can?
We are doing a science experiment and I NEED to know
tobyker says: Mar 5, 2011. 10:12 AM
The whole point of this experiment is that it shows how condensing steam causes a vacuum and the can is crushed by atmospheric pressure. This shows how the first steam engines worked.
Kiteman says: Apr 22, 2008. 12:48 PM
Is that you in the video, or your teacher?
By the way, can you fix all the "u"s, please? Site policy is to use proper spelling and grammar.
tyty100 in reply to KitemanAug 5, 2008. 3:08 PM
I didnt even notice it. So why would U
Kiteman in reply to tyty100Aug 6, 2008. 3:39 AM
It's part of what I do here.
bigfootduck in reply to KitemanJun 13, 2008. 8:56 PM
Why do you have to type it "you" instead of "u"? No one really cares, as long as they understand it. But don't get me wrong. I will try my best to follow the policy.
Kiteman in reply to bigfootduckJun 14, 2008. 2:16 PM
Well, obviously at least one person cares, because I mentioned it ;-)
The point is two-fold;
  • If you care enough to post the project, you should show you care by putting the effort in to present it properly. If you don't care, don't post.
  • We have a lot of international members and readers who do not speak or read English as well as you or I, if at all. We need to make our writing as clear and correct as possible so that they can understand it in translation (especially if they are using something like Babelfish).
Thank you for you efforts with this - it is more important that it seems.
Miro95 (author) says: Apr 29, 2008. 9:03 AM
ya but that is me i am inn high school!
ac1D says: Apr 22, 2008. 4:14 PM
only problem, it was posted X time here before. nice instructable tough.
foxpox says: Apr 22, 2008. 11:24 AM
yep me science teacher did that for us
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
