Crutch Chair
Crutch Chair
  • last photo ←
This chair is made from an old pair of wood crutches and some oak, held together with assorted fasteners.
Since crutches are designed to support the weight of an adult human (~180 lbs, give or take), it goes to reason that their weight-bearing structure could be re-arranged into a chair. The crutches don't have enough wood in them to make the entire chair, so I dug some white oak left over from another project. I had three pieces,1"x3", about 48" long. I tried to waste as little material as possible, and re-used as many fasteners from the crutches as I could.
The design was derived by just cutting and hold pieces up,evaluating, then pre-drilling and screwing them together. Since I designed it as I made it, there are some things I would change if I were doing it over. For one, the dowels that run from the crutch armpit support back down to the feet like secondary legs could probably be eliminated if the front legs were pushed forward to sit at the very front of the horizontal feet. Then the feet would be long enough to resist the force of a reclining person from tipping the chair over backwards.
The angle of recline is rather severe; the back is also pretty short, providing only lumbar support. However, the chair is really very comfortable. Getting in and out is facilitated by the crutch armpit supports, which form handles to push up and off or a handhold for lowering yourself onto the seat. Overall, the front edge of the seat is about 14" off the ground, 26" to the top of the back, 16" wide, and weighs about twenty pounds. Both the seat an the back are 14" x 16".
All dimensions are approximate; since designed it on the fly, nothing was really measured. Everything can be roughly judged from the photos. Every pair of crutches is different, so you will have to experiment with your own materials. I used the oak because I had it; a number of materials could easily be substituted. After I built it, I took it apart, taped off the joints, stained and sealed it, then re-assembled, gluing the joints on the bare wood left by the tape as well as screwing them. Finally, I buffed in a coat of furniture wax.
Step 1Cuts
Cuts
Separate the foam from the crutch armpit supports and handles. Disassemble the handles, adjustable legs, and armpit supports. Divide the long, curved side pieces into approximate thirds. Cut with a hand saw.
Chop up the 1"x3"s or similar into five pieces approximately 16" long for the seat and back, and two pieces mitered at 45 degrees about 10-12" from long point to long point. Reserve all the wood, including the triangles you cut off for later use.
11 comments
Nov 1, 2009. 9:11 PMblakvswite says:
would this work with metal crutches?
Dec 3, 2011. 4:23 PMdragonsniper says:
ya.....no lol
Jul 31, 2010. 9:42 PMaadball504 says:
Very Cool and I think every good will and salvation army store has a barrel of crutches for sale cheap!!!
Jun 9, 2009. 3:35 AMKoosie says:
Smart looking chair. Looks a bit fragile for my heftyness, though.
Jun 5, 2009. 11:56 AMaeray says:
Excellent! Very "clean" and green, and stylish too.
Jun 4, 2009. 5:26 AMPrncssGeek says:
This is the coolest "reuse" project I have seen in a while! Good work!
May 31, 2009. 9:23 PMporcupinemamma says:
totally cool! thanks for a great instructable.
May 31, 2009. 6:46 PMiluvpandas4 says:
this is pretty neat, it reminds me of those folding TV dinner tables.
May 31, 2009. 9:07 AMbesttarzan says:
Very smart and nice project. I love this project.
May 31, 2009. 3:49 AMNinzerbean says:
Fantastic!
May 30, 2009. 8:31 PMjessyratfink says:
The finished project looks really nice. Great work. :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
377
Author:wholman
I am an artist, writer, and designer who graduated with a degree in architecture in 2007.
