3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cryptap: A rhythm-based door lock
Step 4Wiring it together
Wiring it together
The Teensy was no problem. It comes with pins, so you can plug it directly into the breadboard.
I decided to color-code the wires to the door strike with red (+) and black (-) banana cables from the lab's broken parts box. There were some plugs chopped off from their wires, so I dremeled away some plastic to expose a solder point. I really like how the lab banana plugs can plug into each other.
I used Apple's phone cable to connect the buttons and status light outside the room to the Teensy inside. Since one side was broken, I chopped off that end and soldered in the four-pin header, sealing it off with hot glue. This plugged nicely into my breadboard. The side that I left the plug on went into the modular jack I salvaged from the router. All four wires were used (GND, status light, start/stop button, code button).
In case you haven't noticed, I like plugs and connectors. The power brick connected to the power jack that I swiped from the router.
Threading the wires through the wall pipes wasn't too difficult, because of the flexible grabber thing. That really saved my day.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MusashiAharon
