Crystal Light With Piezoelectricity | the Precious Light
2,292
30
5
Posted
Introduction: Crystal Light With Piezoelectricity | the Precious Light
GIFs Challenge 2017
Runner Up in the
GIFs Challenge 2017
Hello!
The Precious Light is actually an artwork created during my class of art and science last year. In fact, the piezoelectricity in rochelle salt crystal is not used, so any kind of crystals should be okay to replace the crystals using in my version. I still chose rochelle salt crystal for my project because of its color and transparency.
I want to write my first Instructable, so I share its making process.
Step 1: Refer to Existing Tutorials
After having an idea of using the piezoelectricity, learning from the existing projects or tutorials would be very useful. I simply refer to a few links as follows:
Step 2: Prepare Materials
Growing Crystals
  • Potassium Sodium Tartrate (Rochelle Salt)
    - As I was able to get potassium sodium tartrate from the class, I didn't use soda ash and cream of tartar to make the potassium sodium tartrate
  • Beaker x 1
  • (**not used anymore) Pot x 1
  • Wrapping Wire (black) x 1
  • Fishing Wire x 1
  • LEDs x 6 pcs
    - preferably white LEDs
  • Bottom Part of Plastic Bottles x 6
    - grow the crystal
  • Distilled Water
    - tutorials usually suggest to use distilled water in order to ensure the purity, but I didn't use it
  • Hot Glue Gun & Hot Glue
  • Needle & Thread
    -for hanging the LEDs
Piezoelectricity
  • Piezo Discs x 6 pcs
  • Soldering Iron
Making the Stand (any materials)
  • Wood Board x 1
  • Bamboo Sticks x 4
Step 3: Get the Seed Crystal
After making the crystal solution according to the reference tutorials, I poured the solution in one plastic bottle.
My Small Tips
  • cover the cup
  • don't be too shaky when you are holding it
  • put in the fridge
  • let it grow overnight
Step 4: [Optional] Take a Look at the Crystals
After the crystals finished growing, I put those on a little microscope to take make a record.
Step 5: Test All LEDs
Before getting the LEDs to be ready for growing the crystals, I put hot glue on the LED to hang the string on (and also split the negative and positive) for the crystal growing.
Step 6: Grow Crystal on LED
Refer to the "LED Crystal Procedure" instruction
  • Check the LEDs again
  • Tie the seed crystal with a long thread
  • Follow the photo instruction:
    1. Put hot glue on the LED
    2. Take the needle with the thread and a fish wire
    3. Get it through the hot glue
  • Tie the fish wire with the crystal on a stick
  • Put in the crystal solution
  • Cover the beaker with a lid or cover
  • Put in the fridge
Step 7: Solder the Piezo Disc
  • Solder the piezo discs with wrapping wire
Step 8: Wrap Wires on Crystal LEDs
Step 9: Prepare the Stand
  • 30 x 30 cm wood board x 3 pcs
  • 30 x 5 cm wood board x 4 pcs
[Refer to the illustration]
Drill 2 mm holes x 20 on only one 30x30cm wood board
I used my soldering iron to make the holes.
-- putting wires of LEDs -- dark blue
-- putting wires of piezo discs -- light blue
-- putting bamboo sticks -- orange
Step 10: Connect the Wires
Connect the wires of LEDs and Crystals in pairs according to the same numbers.
Step 11: Enjoy the Crystal Light
  • Thanks!Yes! https://...-JAN_ET
    JAN_ET made it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
2 Comments
Add an amplifier (transistor) and some PWM and could make the intensity variation more apparent.
Interesting idea, that is really pretty :)
