I decided to make this a low voltage DC project...
Remove these ads by
Signing UpStep 1You will need
Clear light bulb
quartz crystal that will fit inside of the light bulb
Plastic light socket (home depot sells this for $1.40)
Wall Wart, 5VDC
Regular household copper wire ( about 10 inches)
3 LEDs ( I chose amber DIgiKey part number 160-1653-ND)
150 Ohm 1/4 watt resistor
1 1K Ohm Pot ( this was an old spare with a click off switch on the low side, sorry no part number)
3/8 inch flat rubber washer
I really like this lightbulb, but lack soldering tools and the skills to use them. Would buy one though.
Sounds great!
Thank you
too bad theres an led in there :(
Enjoy it!
In Canada it starts with Zed...
Don't bother racing to post, as you'll win anyhow, on account of my being generally lazy and shiftless.
I think my "things I should get around to sometime" list is well into the hundreds by now.
for extra awesomeness find a base with room for a AA battery or 2 and use a joule thief circuit...
I didn't think you could use dimmer switches with leds, unless you have special dimmable leds. How does this work?
While the preferred method of dimming a LED is PWM, The quick and dirty way is to limit the current available to the LED by increasing the size of the resistor in the circuit.
Since the brightness of a LED is dependent on the current of the circuit, to decrease the brightness of a LED you need to either decrease the voltage available or increase the resistance of the circuit. There is a limit to the amount of current that the LED can handle which is why the circuit uses both a fixed and a variable resistor. Make sure that the potentiometer that you choose can handle the power, In this case a 1/4 watt rated pot would have worked but I was going for a specific look.
Note that the resistance circuit used here will result in a differing brightness in the individual LEDs due to manufacturing but this is not seen here due to how they are mounted.
I hope that this helps...
I'm going to try and make it over, nice job!
If you have any questions just let me know.
Good luck with you project.
