This project can also be done with super glue if you don’t have means to solder.
The third picture is as shown on my daughter's little hands.
Step 1: Strip a coat hanger
Use sand paper to remove any coating on a section of coat hanger. To help speed up the process I spun a piece in my drill press.
CAUTION! If you do it this make sure to hold the wire before you turn the drill on. Otherwise the section of wire will turn into a whip / weed wacker. Be careful and work within your experience.
Belana says: Nov 30, 2012. 4:33 PM
genius
stephenniall says: Oct 6, 2012. 3:36 PM
Think i'm going to have to try & make one of these. I'd imagine it wouldn't be too hard to zinc/silver plate it to stop it from rusting. I'll have to experiment & post my findings.
puddingpet says: Jan 6, 2012. 8:16 AM
I think I've seen coat hanger wire straight, uncoated at the hardware store before.
Penolopy Bulnick says: Dec 16, 2011. 9:24 AM
So adorable!
dolwiz says: Nov 14, 2011. 5:13 PM
I love this idea. My boyfriend could propose with this and I wouldn't love him less, probably more knowing the effort he would put into it..
mcshawnboy says: Apr 29, 2011. 7:16 AM
In step 3, if tape doesn't keep it in place you can get something used by lapidaries to mount stones for shaping called "Dop Wax" is about $10, but would likely last a lifetime. Here's pot to heat it easy & safe, reheat it to remove after polishing. : ) http://www.kingsleynorth.com/skshop/product.php?id=94265&catID=1125
psuddeth says: Mar 21, 2011. 6:02 PM
Whadaya coat it with to keep it from rusting?
Mrballeng (author) in reply to psuddethMar 22, 2011. 12:03 AM
You can use clear nail polish. I have not noticed a problem with rust yet but then again I live in a desert.
nanosec12 says: Mar 17, 2011. 11:13 AM
I would monitor this carefully, especially with small children. Most coat hangers are made of a low grade steel, which will rust from the moisture on your skin. This can leave a reddish stain to the skin that is hard to wash off, but will eventually come clean.
Other than that, what a great project.
Mrballeng (author) in reply to nanosec12Mar 17, 2011. 1:03 PM
Don't worry I used a Tiffany Platinum hanger. Actually it's a regular coat hanger =).
Thanks for the advise, I'll keep an eye out.
tkjtkj in reply to MrballengMar 21, 2011. 2:32 PM
i had no idea that one could solder steel ..
old dog + new trick !
srilyk in reply to MrballengMar 20, 2011. 7:11 AM
You can coat the hanger using a clear coat polyurethane. It won't be perfect, since it will chip and you'll have to re-apply, but at least it will work for a while. You also might experiment with anodizing - you can get several different colors of anodization. Of course it increases the price slightly...
You can find instructables about anodiztion.
Pie Ninja in reply to srilykMar 20, 2011. 11:20 PM
You can't anodise steel; the properties of rust make it impossible (well it is possible, but entirely pointless). With Aluminium or Titanium, you get a tightly locked layer of oxide. But with steel or iron, you just end up with flaky rust, exactly what you're trying to avoid.
The best solution would probably be a coat of paint or lacquer; or, better yet, use aluminium and anodize it :P
coopgrl88 in reply to Pie NinjaMar 23, 2011. 6:25 PM
can you electroplate it?
nanosec12 in reply to coopgrl88Mar 24, 2011. 3:29 AM
Yes, of course you can.....You can use any of several methods to plate it with silver, gold, platinum etc. But, honestly, I believe that this was supposed to be an easy/inexpensive craft to do with/for children. Taking it to the electroplating level is a bit beyond the scope, but entirely possible.
BobCat says: Mar 20, 2011. 6:52 AM
I hope that you used lead-free solder. You should warn people against using leaded solder in the instructable, too.
tkjtkj in reply to BobCatMar 21, 2011. 2:31 PM
good point , but i think people ought to know that under federal law, 'leadless solder' can contain up to 5% lead !!!
and never drink tap water out of the hot side: the lead laws are only of recent vintage, like the 1990's .. and hot water + old lead in older pipes means the water will dissolve some ..not good!
Always (still!) wise to run the cold water faucet a while, in the mornings!
RedneckEngineer says: Mar 16, 2011. 1:06 PM
Are you rounding the edges any on the inside? Just wondering if you had any issues with it rubbing or cutting the finger when it's worn. Another great looking ring sir!
Mrballeng (author) in reply to RedneckEngineerMar 17, 2011. 9:03 AM
Yes, while the ring is on the sand paper wrapped drill bit I remove any sharp edges. But since the coat hanger was round to begin with the edges aren't very pronounced anyway.
scoochmaroo says: Mar 16, 2011. 10:58 AM
Awesome! I think the second or third picture in the Intro step would make for a more striking main image.
Mrballeng (author) in reply to scoochmarooMar 16, 2011. 12:21 PM
Done. Thank you.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
