Step 10Second filtering to remove (most) remaining carbon particles
First, heat up the solution. It doesn't have to be boiling, but a hot solution will give a higher flow rate through the filter. While it's heating, wash out the empty container you're going to use to receive the filtered solution; if it's the one you poured the solution out of in the previous step, don't just rinse it - wash it with a little soap and a cloth or rag, to make sure all carbon particles are removed. When you finish rinsing it out, do not dry it with a towel or anything else! Shake it out, but leave it wet.
This filtering step will use six coffee filters at a time. If you're lucky enough to have a lab stand with clamps, you can use it to hold a funnel over your receiving container as shown in the picture (get 'em cheap at American Science & Surplus). If not, no worries - you can use your strainer instead. If you use the strainer, just be certain to wash it carefully beforehand (again, wash - not just rinse), so that no carbon particles remain that could contaminate the filtered solution.
Place six filters, nested together, into your clean strainer and set it in position on your receiving
container; or, if you're using a funnel, fold the stack of filters the way you were taught in science class - flatten them into a circle (all together, not individually), fold the circle in half, fold that in half again, and open one "pocket", forming the folded filters into a conical shape that fits into the funnel.
Using a one cup measuring cup (or similar small container with an appropriate lip for pouring), fill the filter with hot solution and let it drain. Keep transferring hot solution into the filter until all solution has been filtered. If flow through the filter slows down too much, you can replace the filters. Be careful not to overfill the filter.
While you're waiting for the solution to filter, blanch one head of cabbage... (oh wait, nevermind, that was for dinner...)
comment
Add Comment
GentleMiant
says:
GentleMiant
says:
Add Comment
