3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Crystallization of homemade sodium acetate
Step 15Try it out!
Try it out!
After your final solution has cooled to near or below room temperature (it doesn't have to be cold), it's time to see if you can trigger crystallization.
Gently set your container down on a hard surface and remove the lid or covering. Using tweezers (or clean, dry fingers), pick up one or two small crystals from the test dish you set aside in step 13, and drop them into the solution.
You should see a mesmerizing "bloom" of long, thin crystals growing outward from the crystals you dropped into the solution, growing at maybe 1 cm / sec.
Pick up the container after crystallization finishes - note how warm it is. That's excess energy, effectively stored by the supersaturated solution, and released when the sodium acetate crystallizes.
Note also that the crystals you see in the container are actually sodium acetate trihydrate. Once crystallization begins, one sodium ion and one acetate ion will join together with three water molecules. If you were to gently heat these crystals, as the water is driven off, they'd turn pure white and powdery (instead of milky white and translucent), and you'd be left with anhydrous sodium acetate.
After crystallization, recharge the solution while still in the same container by double boiling it - place the container into a pot, fill the pot with water to or just below the level of the solution in its container, and bring the water to a boil. If your container is sealed (with a lid or stopper), you'll want to break the seal first to allow for air expansion and contraction during heating and cooling.
Here's a video showing about 525 mL of my solution doing its thing:
9 comments
Sep 28, 2011. 6:40 PMskulendran says:
hey, i was just wondering. you said if you heated the crystals, water would be driven off and it would produce a white powder (anhydrous sodium accetate). but how would you go about doing that? could i just put the crystals in a pan on low heat?
Oct 8, 2010. 12:10 PMErebo2005 says:
Good, clear and simple. Thanks
Nov 1, 2010. 1:26 PMh0meIandsecurity says:
LISTEN EVERYONE!!! LISTEN, LISTEN! IF YOU WANT IT TO BE CLEAR (NOT DARK OR BROWN) YOU WILL DO ALL THE SAME BUT REDUCE TEMPERATURE OF BOILING AND INCREASE TIME!!! :=)
May 1, 2010. 2:25 PMryanmuller says:
All other sodium acetate I've seen dissolves clear in water... is there any way to achieve this? I need it to look like plain ordinary water.
Jun 23, 2010. 1:50 AMdragon181818 says:
For a "water" look, you will need either: laboratory grade chemicles or to buy it online. About 500 grams is like $25 If you need help, consult youtube :)
Jan 27, 2010. 5:14 PMPizzapie500 says:
Cool! But I'm not "too much of a nerd" so I bought the sodium acetate of ebay. For some reason, mine was like 20 times faster than yours, and it would go off w/o me putting a crystal in it. I made this like a year ago and kept some in my fridge. Do you think I can bring it to school to show my teacher? Or will it go off in my backpack?
Mar 11, 2009. 3:36 PMquaggaquagg says:
Amazing! Although it IS obvious that you used a sodium acetate solution. Can't fool us! Ha ha ha!
Jan 9, 2010. 11:05 AMpatcullen says:
 quaggaquagg must have fallen asleep for the first 14 steps of this tutorial... thanks for taking the effort to post this - im gonna give it a shot tomorrow.
Jun 3, 2009. 12:14 PMKaber says:
For how long do I recharge (double boil) the crystals? and will this cause them to be a white, powdery substance? Thanks
Aug 17, 2009. 5:57 AMminime12358 says:
Just curious, is it necessary to recharge in order to make hot ice with it? And what kind of container could you put in boiling water without exploding or melting?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:indigoandblack
