Step 16Additional purification
I knew that sodium acetate is not very soluble at all in isopropanol (isopropyl alcohol), and it occurred to me that i could essentially "wash" away most of the impurities from the crystals after crystallization. There's no real chemistry here - it's just the mechanical action of the liquid isopropanol that does the trick.
Crystallize your solution in a beaker or a bowl; after it's completed, use a clean glass rod or a clean fork to break up the crystals as thoroughly as possible, yielding an amber colored mush of small crystals and remaining liquid and impurities.
Then, a couple of tablespoons at a time, "wash" the crystals with isopropanol in a coffee filter in a small strainer over an appropriate collection container. It's best if you can use a wash bottle to hold the alcohol; otherwise, pour it in small amounts at a time. You can agitate the crystals with a glass rod or small spoon. To help with drainage, periodically sweep away the crystals from the center area of the filter (be careful not to rip the filter doing this).
I went through approximately two liters of isopropanol to wash my entire batch of crystals. It's not very cost-effective, but it's worth the fun of learning.
After cleaning the crystals, you'll want to eliminate residual isopropanol. The only practical way to do this is to spread the crystals evenly inside a large baking dish and heat them, driving off both the isopropanol and the water. I did mine in several small batches in my oven, at 230 degrees F or so, holding the oven open slightly by closing it on a heat-proof trivet, which allowed some air circulation (to avoid igniting the isopropanol vapor).
Check the crystals after a half hour or so. You may need to break up still-moist areas with a spoon. As the water is driven off, the trihydrate will turn into plain sodium acetate (anhydrous). When it's finished, it will probably be a light, puffy mass.
Once the crystals are dry, you will need to redissolve them in fresh distilled water. Use about 50% more water than the volume of the solution you started with. (That is, if your supersaturated solution was 200 mLs, add 300 mLs.) Heat the solution to almost boiling, filter it to remove any dust or other contaminants (using 4-5 coffee filters - see step 10), then boil off the excess water again as you did in step 12. You'll need to boil off at least the 50% extra volume of water that was added. A small amount of sodium acetate will have been lost in the washing step, so the resulting volume of supersaturated solution will be somewhat less than what you started with.
16
comments
Add Comment
killbox
says:
Soupraok
says:
Add Comment
