3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cultivating in test tubes! / Como cultivar en tubos de ensayo!
I've always been interested in microbiology, microcultivation and hydroponic cultives, but I couldn't help but notice that there isn't a lot of information for the "small scientist", so I've decided to do some experiments on my own.
These are the results, tell me what you think!
IMPORTANT: This involves working with fire and flammable things, if you're a minor, do it in company of your parents or someone responsible.
Siempre estuve interesado en la microbiología, microcultivos y cultivos hidropónicos, pero nunca pude encontrar información clara y util para el "pequeño científico", por lo que decidí realizar algunos experimentos.
Estos son los resultados, diganme que piensan!
IMPORTANTE: Esto involucra trabajar con fuego y cosas inflamables. Si sos un menor, hacelo en compañía de tus padres o alguien responsable.
Step 1Materials / Materiales
These are the materials I've used:
- Test tubes: As you can see from the pictures, I've used the ones with threaded caps. It's important to have a way to seal them, but you can use cotton plugs instead if you have conventional tubes.
- Pressure Cooker: This would be the ideal thing, but it's not really common to have one and, as you'll see, I don't. I've used an aluminum pot with an almost hermetic lid.
- Agar-agar: Is the medium where we will put the seeds. It's made of algae, that's why the vegetarians use it as a replacement for the conventional gelatin. You can also use tasteless colorless gelatin, but the agar-agar would stay solid at higher temperatures than the gelatin. This is important because you should keep the tubes in a warm place, and if the gelatin liquefies, the seed will end in the bottom of the tube.
- Fertilizer: As we said before, the agar-agar is made of algae, but it's not very "tasty" for the plants to grow in, so we will make it tastier with a few drops of fertilizer.
- Seeds: Yep, the whole idea is to germinate some seeds, right? You can buy them or collect them from the actual plants. You may also want to find if the seeds have some special requirements prior the sowing. In my case I've used red tomato and red pepper.
- A flame: The ideal would be a Bunsen burner, but then again, not everyone has one of those. The alternatives are a alcohol burner, a torch or, more simple, a kitchen burner.
Estos son los materiales que usé:
- Tubos de ensayo: Como pueden ver en las fotos, usé unos con tapa a rosca. Es importante poder sellarlos de alguna manera, pero en el caso de los tubos de ensayo convencionales se pueden usar tapones de algodón.
- Olla a presión: Esto sería lo ideal, pero no es común que cualquiera posea una olla a presión y, como verán, yo no tengo. En mi caso usé una cacerola de aluminio con una tapa casi hermética.
- Agar-agar: Es el medio donde pondremos las semillas. Esta hecho de algas, razón por la cual los vegetarianos la usan como reeplazo de la gelatina convencional. Se puede también usar gelatina sin sabor ni colorantes, pero el agar-agar se mantendrá sólido a temperaturas más altas que la gelatina. Esto es importante ya que los tubos deben conservarse en algún lugar cálido y si la gelatina se licua, la semilla caerá al fondo del tubo.
- Fertilizante: Como dijimos antes, el agar-agar está hecho de algas, pero no es muy "apetecible" para las plantas, por lo que le agregaremos algunas gotas de fertilizante.
- Semillas: Parte esencial, ya que la idea es germinar algo en este medio, no? Pueden ser compradas o recolectadas de la planta. Depende el caso, puede convenir buscar información acerca de los requerimientos de alguna semilla en particular previos al sembrado. Yo usé tomates rojos y pimientos rojos.
- Una llama: Lo ideal sería un mechero Bunsen pero, nuevamente, no cualquiera tiene uno de estos. Las alternativas son un mechero de alcohol, un soplete o, más simple, la hornalla de la cocina.
12 comments
Feb 6, 2011. 2:42 AMP1NCH0 says:
Muy buena guía, gracias.
Se podrían utilizar semillas más grandes, ¿no? Estaba pensando en plantar una semilla de mango usando este sistema. Y, ¿se le puede añadir algún estimulante de creciminto de raíces a base de hormonas?
Porcierto, en la versión española no has puesto la parte de añadir el fertilizante al medio.
Gracias
Feb 6, 2011. 12:46 PMP1NCH0 says:
ok, gracias por la respuesta, lo intentaré en cuanto tenga una semilla de mango.
Pero los envase de gatorade son de plástico ¿no se fundirán con el cono de fuego?
Feb 7, 2011. 9:19 AMP1NCH0 says:
Aaaah... vale... muchas gracias por la aclaración.
Y una dad más sobre el del estimulante de raices: el que yo tengo es a base de hormonas. La mayoría de las hormonas spn proteínas (no se si este es el caso, supongo que si) y las proteínas son extremadamente sensibles a cambios en temperatura. Por lo que no creo que se pueda añadir al medio antes e la esterilización. ¿Que hago? ¿le añado el polvo a la semilla y luego la añado? Se supone que ha de hacerse así, pero supongo que eso comprometerá la esterilidad del medio.
Muchas gracias otra vez.
Feb 8, 2011. 8:55 AMP1NCH0 says:
Muchísimas gracias por las aclaraciones
Jan 6, 2011. 12:47 PMMr. E Meat says:
Nice Instructable!
What sort of experiments would you need to start seedlings on agar for? I understand the Instructable but not the purpose.
Could you please explain the "sterility cone" better? Maybe post a diagram...
Jan 6, 2011. 4:48 PMMr. E Meat says:
Thanks for the response! That clears up a lot for me. I may just try starting some seedlings in agar for my garden this year!
Jan 4, 2011. 12:29 PMlobo0x7 says:
está muy bien explicado y no conocía el truco ese del cono de la llama.
tengo una duda:
parece un poco contradictorio tener tanto cuidado en la siembra para evitar la contaminación y luego se dejar los tapones semiaabiertos, no?
un saludo
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:SentencedToLive
Chemistry Technician, some background in electronics and informatics, actually working in an environmental laboratory.
