Cup Cone Mini Lightbulb Holder
Published
Introduction: Cup Cone Mini Lightbulb Holder
About: thinkers with electronics and still life photographer
I was wondering if i could make a little incandescent light bulb holder. and came up with this solution.
Pretty much because these holders are a bit hard to find (mini incandescent light bulb holder)
Parts needed
(x2) cardboard coffee cup. (more than 2 is maybe vice)
(x1) mini incandescent light bulb
(2" by 2") sheet of aluminium paper
(x2) split paper holders
(x2) 1.foot long wires
(x1) power source
Step 1: Make a Little Holes
You need to make about 5 holes in the top cup. four around and one in center.
The hole in the center needs to be about as little as you light bulb skrew is. not to big.. just so that it passes trough. just abit smaller.
And then you have to bend a splitt pin holder along the edge of the hole
Step 2: The Innercup Connector
here you need to make a little hole. But not in the center. In fact as long from center as possible.
cut a aluminium paper for the desired size
use glue if you want.
then you push the paper splitt pin in the hole, and secure it
Step 3: Copple the Wires to the Splitt Pins
Run wire from top connector (paper splitt pin) and make a hole to it in the other cup so it goes trough.
Connect bottom connector (paper splitt pin) to another wire.
Step 4: Now It Is Ready to Assamble
pull the wire as you top the cones tog heter.
Step 5: Screw You Light Bulb Down
Screw you lightbul down. (maby lift the top cone first)
Step 6: This Could I Use.
this could i use.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
