loading
Step 2: The brine
This is very simple.
You heat some water and start adding salt. I've not bother to measure it in most cases as the ideal according the vast majority of sources is to add salt until an egg floats in the water. That would be an uncooked and unbroken egg.
Gently heat a quart or so of water and add a half cup of salt. You'll need more than that but it's a good place to start. Once the salt dissolves see if the egg floats. If it doesn't, add more salt until it does.
Once the egg floats you're brine is strong enough. Set it aside and let it cool while you crack the olives.
This is a very basic Instructable. There have been some very helpful comments so far and I would strongly encourage anyone who has worked with olives to post additional Instructables! Olive season is a long way off but I'm already thinking ahead about posting something more involved when the time comes. So, thanks again for everyone's helpful comments and please post so we can help others and encourage more people to try curing olives.
I have tried to do my own brined batch of olives. It has been approx 2 months since bottling and I tasted it tonight. The olives are starting to taste really nice but I did notice a slightly acidic/fizzy feeling from biting into the olive. Is this bad? Or is this the olives still curing?
<p>My first batch of olives went mouldy when I tried to cure them from a very old recipe. A couple of years ago I did not soak in water for 2 weeks. So I recommend, putting a gash in each olive and immersing them in plain water and soaking for 2 weeks and change water every day. </p>
This is my first year with olives I just picked the only ones I had off of my small tree. Some are green and some are very dark I would like to get the instructions on how to salt brine . So far this is what I have done . I heated salt water until a fresh egg floated in the water to let me know that the water was salty enough After washing my olives I put them in a pint jar and filled the jar up with the salty water Here is my first question. Was I supposed to leave an airspace in the jar or fill it all the way to the top? My second question is do I keep the olives in the same water for the remainder of the curing process or is it best to change the water on a regular basis, always using salt water? My third question is about the cracking of the olives. Before putting them into the salt water, I put my clean olives and a dishtowel and smacked them with a rubber mallet. Do I have to hit them hard enough to crack the skin or just to kind of soften and smush them? Any other advice for a first timer will be very appreciated. Please don't leave out even the tiniest detail. Thank you all so much!
<p>I cure my olives with lye.</p>
I hope someone can help be with an answer to this... <br> <br>We are trying to cure olives and are using a family recipe to water cure them. The recipe calls for fresh water soaking, olives fully submerged. water changed every day for as long as it takes for the olives to lose their bitterness. The olives have been in water for 20 days and they started to get mushy. Literally in one day they went from looking great to looking &quot;bad&quot; and I noticed there were many that seemed to have changed from firm to very soft overnight. My question are : <br>Are the olives no longer good? <br>Will they be safe to eat if we brine them? <br>What did I do wrong? <br> <br>Any help would be fantastic! <br>Thanks, <br>Yogi
I am sure there are more expert olive folks on here but I do know that once they go mushy they are not fit to eat. Mine have never lost their bitterness from fresh water alone, needing the lactofermentation in the brine to cure fully. The most anyone I spoke to has soaked them in fresh water is about ten days before brinaing. As far as I know you can just discard the mushy ones and brine the rest but others may know better. <br><br>Lots and lots of ways to cure olives, even losing a batch helps you learn about it.
I have about 700 olive trees.I am not an expert but i know some things about olives.<br>The first and most important thing is that there are hundreds of different types of olive trees.Each olive type tastes different.Also the time of the harvest is very important,sooner you get greens that are bitter,later you get red or black that are 'swetter'.<br>So it has to be cured in a different way.<br>So the best thing you have to do is to know what olives you have,and cure them properly.<br>You can smash or cut the olives(there a special equipment doing it that costs 5-10 euros).If you do that,you will speed the curing period very much.Especially for the green olives.But they wll not last for a long period.And the bad thing about cutting is that the olives are getting 'juicer'.Lot of people don't like that.<br>If you use salted water when you 'de-sour' them,they will become more tight and they will get saltier taste.If you use plain water they will become juicy and they will have less saltier taste.The time for the curing depends on the type and the time of the harvest.Some needs only a week with daily change of water some may need 3 months.Always try and taste them.You will know when they are ready.<br>You can preserve them in olive oil,in vinegar or salted water with almost any seasoning you like.Only remember if you try vinegar or salted water,add a little olive oil in the top,because they will rot elseway those that react with the air.<br>The easiest way for me for making olives is the burlap sack way.<br>You get some black olives,you put them in a burlap sack and add salt.You shake the burlap,and you hang it with a bowl underneath it for 2-4 weeks.You remove the salt,put them in a bowl,add some olive oil an oregano and they are ready.<br>Last thing,if you don't own an olive tree and you buy the olives try to buy biological or olives that are from high altitute.The reason is that (al least in Medditeranean)there is a little fly that nest its eggs inside the olives.So the olive tree's farmers spray the olives.The most pesticides for killing those flys are very toxic if there is not enough time from the spray till the harvest time.<br>
Thank you for an information and description. I am interested in that equipment you mention for smashing or cutting olives, I can't any in google, would you specify? <br>warm wishes <br>Ieva
Do you currently have any olives this year October 2013, and do you sell them, ship them to U.S.? May be a little late, but I'm interested any time of year. Great info, I will pass it on to my friends in olive curing to help them simplify. I personally love the salt curing and your burlap curing, I just love the wrinkled (dry salt-cured) black olives with herbs, especially Herbes de Provence and olive oil. Picholine are also delicious. Thanks so much.
No unfortunately right now i don't have any left.It is too early,olive harvest time starts in november and later,so it is not possible for any guy to have fresh olives in Octomber.If anyone have, they will be last year's,and olives usually last up to a year(there are some types of olives that can last up to two years or a litlle more sometimes but i don't have any of them).So usually after a year most olives begin to rot.Therefore it won't be wise to buy last year's olives a month before the fresh harvest. <br>This year i will not have a lot of olives(olive trees usually have production every 2 years) and i have never shipped any food in the US,so i don't know if it is possible(to ship raw foods outside the country and how it is done).But if you are interested i can ask around to see if anyone i know can do this.Price here is about 2.5 euro per kilo raw and uncured,and 4-6.5 euro per kilo for the cured
I understand. Here we have had very bad olive harvest, usually done by now but there were bad flies so not many had good harvest. I am looking for all kinds of olives, raw uncured so I would truly appreciate your asking around in time for the new harvest. If available, I will also contact others for a larger order if possible. I salt cured Sevillano and Spanish Arbequena from my own small tree last year and we have a lot of Mission Olives around, but they weren't great either. I do know some people have olives in the January/February here, but supply is very limited. Thank you so very much for getting back to me my friend, I really appreciate it. My favorite is Picholine, but I haven't cured that kind yet, we love all kinds. I look forward to hearing from you when you have news. Thank you so much.
I have been making olives for over 20 years and we always keep them on the counter, we soak them in plain water first and rinse many times a day then we add the salt, the salt will keep you from getting botulism, salt is a natural preservative. Boltulism mainly is root borne bacteria, more like raw garlic not olives, Make sure you put a little vinegar or lemons when you store it in the fridge. <br>Yes Tariast, I don't know about this recipe but when I am finished I put these olives in jars with oil, vinegar inions and several seasonings like oregano and celery, salt and pepper. I have never been afraid of bolutlism after 20 years I don't think that really is a problem especially since we made them for many years in our hot kitchen in late summer with no A/C
Hey thanks! That's really helpful. <br><br>I recently moved the jars from the fridge to a cool pantry that was predictably not as cold at the refrigerator and it seems to have allowed the olives to cure a bit more and &quot;better&quot;. The warming up seems to have allowed them to lose the last of their bitterness and so far I'm not sick and they show no signs of going off.
When you are curing you shouldn't do so in a fridge. The temperature in a fridge slows down all chemical reactions, including the ones you want to happen in curing!
Hello<br>First of all, i'm happy to hear of people making olives ( that are not in close reach) <br>I live in a place ( Israel) surrounded by olive trees / for the past few years i;ve been making big batches of Olives..<br>I have a few things that might make your olives safer,tastier and faster..<br>First of all, the common way in which we make them is to break them ( or cut them) an then soak them in water for a few days, changing the water freaquently ( at least twice a day) - you will see why, the water changes its color and smells olivy..<br>second of all , the jar that you put the olives in, i pour boiling water in befor putting the well rinsed olives in. following by putting layers of olives- lemon/garlic cloves/ black pepper, whatever you wish.. and more olives.. layering the stuff in between..<br>Third and most important.. <br>after putting the olives in their salty water, most important is to pour oil above all of it, to prevent oxygen entering inside, this makes everythign safer ..<br><br>what else with this will be,not to fill the bottle... opening the bottle after about a week - there will be a lot of pressure inside waiting to burst.. <br>i do'nt refrigirate my olives.. i leave them standing for about two monthes and then they are ready .. <br><br>Good luck!
what's the problem with oxygen ,what it will not be safer about ?
Oxygen is one of the major causes of deterioration in foodstuffs. In any sort of bottling it is essential to avoid the product coming into contact with oxygen in the air. <br> <br>Oxygen from the air dissolves into the surface of water or similar liquids, but not much into oil, so a layer of oil protects from this.
I'd have to rasie a caution about using milk bottles. Even glass ones are extremely hard to get clean to the standard suitable for bottling - a domestic dishwasher won't do, and standard boiling in water sterilising needs to be followed more stringently than most do - 20 minutes held under boiling water is absolutely required.
Here is a link to a wonderful resource put out by UC Davis. <br>http://anrcatalog.ucdavis.edu/pdf/8267.pdf
Looks tasty. The only thing close to an olive tree here in Colorado though is a Russian Olive, and I'm not even sure they're edible. 8&gt;(
They really are tasty. Mine are admittedly on the simple side and this is probably the slowest way to make them but there are many ways to go about it. Certainly worth the effort. <br /><br />I hadn't heard of Russian olives but Wikipedia says they're an edible sweet fruit! Sounds like something to check out. :) <br /><br />
Yeah me too, may be in green houses in Crimea. Olive trees can't stand freezing their roots but just some clear sky night freezing and in that case you can already give a Kiss to many branches. I don't think there's any open field olive tree northern than 45th parallel .
It also happens to be January while I write this. I may have to wait until next fall, but I plan to try that.
Russian olives are edible, but their not supposed to taste very good. Give'm a try anyway.
i want to know how to water cure olives
In 3-5 weeks or more depending on size, kind of olives, temperature and whatever it just washes away the bitter brown compound (oleorupein) contained in olives. As many other crops you better not to eat them as they are. After 2-3 weeks you'll see a change in color of water, that's oleorupein coming out through olives skin waxy layer . The best is learn the subject and have some practice and anyway try and taste . <br>I red a lot on this on italian sites and I think that many old traditional advices on the subject are nearly mere local superstition or chat and you can see it by the absence of a precise concordance and the almost absence of analysis of the problem.
Botulism is anaerobic, so unless you seal the jars airtight I don't think it will be a concern. The exception to this is if you put them in oil, which air cannot freely circulate through. Keep em refrigerated and add some acid if you store them in oil next. Any mold that forms shouldn't be dangerous. When fermenting pickles or sauerkraut in simply a salt brine such as this you can just skim off any mold that forms, I assume it's the same for olives, though if your storing these in the fridge I wonder if they are lacto-fermenting much at all, so it may be different in that. Of course you should only eat what you feel comfortable with, I just wanted to allay some fears!
Ascorbic acid (C vitamin) could be a good choice, I add some in sauces, marmalades and whatever it keeps colors and and taste fresher
Thanks for the helpful comment! The lacto-fermentation is indeed slower with keeping them in the fridge. The whole process would likely go much faster if I kept them at a slightly higher temperature. It does happen just more slowly.
Great Instructable! I should really try this myself!!
I really like them cracked, when you crack them you wind up with some nice pieces that get done faster and are tastier, to me anyway. <br>I am enjoying your tutorial, thanks
thanks for posting.<br>I cured olives for the first time this year. Didn't know about cracking them. That was helpful. If you don't crack or slit the olives, getting all the bitter flavor out takes much longer.<br>I also tried lye curing. That goes much faster than brine curing, but the flavor is much blander than that of brine cured olives.<br>Someone else has already alluded to this, but one of the things that happens when you put vegetables in salt water is that lactic acid fermentation starts. This produces CO2 hence bubble and pressure in a closed jar. Lactic acid fermentation also produces the interesting flavors. If the curing of olives is anything like the curing of cucumbers or cabbage, then temperature affects the balance of flavors. Lower temperatures, like around 50 degrees F produce more complex flavors. <br>The other thing I noticed when researching the topic on the internet is that after the cure, that is, once the bitter flavor is gone from the olives, people have all sorts of recipes for flavoring the olives with various blends of vinegar, salt, oregano, lemons and so on. This adds yet another layer of complexity to the process and to the flavor.<br>
I failed to crack an early batch as well and it took forever for them to taste even tolerable. <br /><br />One of the reasons I like using milk bottles is they don't seal all that tight. This allows the co2 to escape. Aside from pressure build up in the jar you can also end up with carbonated olives. Funny but not very nice to eat.
Thanks for the instructable! I've been inspired by you! I live near Sacramento California and just picked a couple buckets of olives from my neighbors trees today (January 16th). Find a tree near you and maybe get the courage to ask the owner if you can have some. There are lots of trees in peoples yards here.
That's fantastic! Do take lots of photos. I thought they were all finished for the year. Good luck with your olives!!
I have been curing olives for a long time and was taught by a couple old Italian guys.<br>I use food save 5 gallon buckets or stainless steel containers and I soak them in water for at least 4 months and change the water very day. When the water starts to get clear is when I brine them. I taste test them for bitterness and then I brine them and do it for a couple of weeks and test test again and if it is to salty I reduce the concentration of brine to my taste. I change the brine once a week. Then I add all the oils herbs and brine.
My sincere hope in publishing this simple method was to not only inspire those new to olive curing to give it s shot but to encourage more experienced folks to share their methods. I would love to see an Instructable from you and others who have shared such helpful comments! Thank you for commenting!
Very tasty indeed!!!<br><br>if you took same idea added small cukes and handul dill and head of smashed garlic and a big pinch of red pepper(optional), you get Kosher Dill GArlic Pickles hmmm. Hot weather 3 days, cool weather, (or in fridge), 2 weeks very yummy add a piece of real rye bread to make them greener.<br><br>refrigeration is not required, as long as they are well salted. There is a word in Sicialian that sorta means wack with a heavy wine bottle (empty, sigh ;-( ) and I can barely say, let alone spell. It is how we prepped olives after being brined. If you do it before brining it goes faster. Little old Eyetalian ladies in Brooklyn explained to me the soak in water trick changing daily (two times, per day, minimum) or salt brine and change a couple times per week..<br><br>If you marinate them, they must be refrigerated to below 50 degrees for botchulism safety. If you leave them in a last clean batch of salt water you can leave them be, like pickles, (that is right from the old ladies not me). Adding Cinnomim bay leaves hot pepper flakes cumin/corrinader cilantro parsley garlic oregano etc to a mixture and letting them sit in it (with salted water) will flavor them, then rinse off a week before you want them and add oil and more herbs<br><br>this is a greta instructable..thanks<br><br>sparkie
I''m guessing that Olives come in Cultivars, all those sizes and shapes of olives can't be the same thing. Do you know what preservation method goes best with each variety?<br>What are the varieties one might be likely to find in California? Florida? Elsewhere in the US? Who brought them here? Why, for fruit or for oil?<br>Just wondering---if you know any good books or sources of information I'd be fascinated to take some time and learn.<br><br>By the way, what happens if you eat an uncured olive?
There are different types of olives but fewer than it might look. The multi-colored varied size batch in the photo is one variety. The uniform size of many commercially produced olives is from sorting rather than the fruit itself and how black they are is a factor of when they are picked. They go black toward the end of the season. <br /><br />I've seen trees all over the southwest but couldn't say beyond that. The trees were likely brought here by immigrants for both fruit and oil. <br /><br />I'm sure there are many books on the subject but I've not run across any. If you dig around on the web you can find information though. I've gotten the best information directly from olive growers, either in person or over the phone. <br /><br />Uncured olives are completely inedible! They contain an incredibly bitter chemical. No amount of cooking, flavoring or salting will make them fit to eat. You can cure them any number of ways but you have to cure them. <br /><br />This wiki article on them is pretty good. You might start there. <br />http://en.wikipedia.org/wiki/Olive#Traditional_fermentation_and_curing<br /><br />
Wonderful! Incidently, pickling salt dissolves at room temperature, so you wouldn't need to heat or cool the liquid at all, if using it.
Oh, thanks! I use run of the mill kosher salt. When I learned how to make these we heated the water. I guess I just kept doing it that way and never gave it a second thought.
This is awesome! I had no idea it was so easy. But is it too late to buy uncured olives in January?? I did a quick search and it seems that the 'season' was more like Sept through November. Thanks!!
About This Instructable
418,497views
100favorites
License:
More by Culturespy:Carve a bone needle for naalbinding 9 Volt battery adapter for Arduino Cure your own olives
Add instructable to:
