3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Curing Small Animal Pelts, Squirrels Rabbits etc..
To preserve small animal pelts leading to tanning and finishing. In this Instructable I'm using to excellent Fox Squirrels shot Thanksgiving morning. Some pictures may be graphic :
Materials:
" Sharp knife
" Large flat working surface such as an old work
bench or a sheet of plywood
" Non-iodized salt
note:
This will not make the pelt soft like tanning, only preserve it in a pliable state.
Step 1Go for the head
Go for the head
If you decided to keep the head on, slowly work back the skin with your knife. Be careful not to cut into the hide or you may cause an unsightly gash in your pelt. As a reference, separate the silver skin from the hide. When you get past the eyes, cut around the check muscles then you can pull the rest off.
72 comments
1-40 of 72next »
May 20, 2012. 4:52 PMmisaethewolf says:
Would this also work for a fox pelt?
Mar 28, 2012. 6:34 PMtincanz says:
Does wood ash make a suitable substitute for salt, brain for alcohol, and extensive movement for Neatsfoot oil?
Jan 24, 2012. 9:23 PMstinna2 says:
I have personally gotten the tails out of gray squirrels by pulling them while holding the skin a few inches up from the tail. usually works well. most times you end up with and inside out tail.
Jan 14, 2012. 8:07 AMtywatters says:
u get all the flesh and fat off it and salt good for 2/3 day the u can get the brain out of the animal mash it up then add 1/2 cups of water then rub it in it call brain tanning . ever animal has anough brain to tan its on hide beide bufflo
Mar 10, 2010. 12:04 PMstuff9 says:
 couldn't you just pull the bone out lengthwise
Nov 28, 2011. 2:16 PMducktape.mac says:
i think that connective tissue would hold on to it. now i have seen a way to skin a squirrel with an air compressor, and maybe you could put some air down in the tail.
Aug 29, 2011. 1:27 AMyaspeling says:
can i inject the animal with formalin instead of skinning it
Jul 16, 2011. 3:50 PMkcampain says:
what else can be used if the neatsfoot oil is not available? I don't usually use saddle soap... would a good lanolin lotion work?
May 5, 2011. 2:51 PMaasher says:
You cannot leave that deer in the freezer for too long. If you do it will get freezer burned and the hair will fall out and the hide will disintegrate much faster than a fresh hide, even after it has been cured.
Mar 23, 2011. 4:09 PMbluepandabear says:
does it make the pelt flexible and soft or does it make it hard and unflexible? and does it remove the hair?
Feb 5, 2011. 12:10 PMmatt_and_nick says:
how long do you soak it for?
Dec 18, 2010. 9:32 PMTheEbonyEmoFairy says:
Hey, would this work for skinning a cat?
Jan 21, 2011. 8:18 AMharley_rly says:
great idea man! im gonna start skinnin, all of our cats that get hit
Dec 6, 2010. 1:32 PMjamesbondd says:
hey there, i was just wondering: my rabbit skins always seem to get really dry and brittle, and they tear quite easily.... do you think putting the dry fur into the alcohol, then putting neats foot oil on it will help, or should i change my curing process?
Nov 28, 2010. 5:41 PMmatt_and_nick says:
how did the geer pelt go using this method?
Oct 29, 2009. 2:53 PMsolarpolar32 says:
can you use regular salt idkk were to get uniodizzed
Aug 25, 2010. 3:08 PMskelloween says:
Any salt is fine, unionised is just cheaper. You can buy it at animal feed stores and co ops.
Jul 9, 2010. 3:47 PMrandone says:
canning salt works. you can get that at walmart or grocery store
Feb 14, 2008. 1:59 PMEricGrace says:
did you kill those poor animals
Nov 15, 2009. 7:57 AMZachPosey says:
you say poor, i say tasty.
Mar 11, 2009. 8:15 PMThundertydus says:
Poor? Its the circle of life. Deal with it
Jun 3, 2009. 8:10 PMHuray4Insanity says:
i agree the circle of life, what a perfect shape
Jun 18, 2008. 8:29 AMheinzsinvt says:
Does anyone know a local market for rabbit pelts...Montpelier VT... phillip.heinz@gmail.com
Nov 8, 2009. 9:35 AMJ@50n says:
 Talk with people at your local sporting goods store, usually people make a round every few weeks buying pelts, you just need to know when and where they are.
Aug 19, 2008. 2:21 PMdeer-slayer51 says:
can i do that with a deer pelt
Nov 8, 2009. 9:33 AMJ@50n says:
 i dont see why not, just got A LOT of salt :)
Sep 12, 2009. 3:11 PMiheart7s says:
Oct 30, 2009. 3:46 PMiheart7s says:
it was a lucky draw on google... i'd been looking for a way to do this so thanks for being awesome and posting it for all!  I <3 U!
Dec 25, 2008. 11:25 AMlukechewypellets92 says:
Im pellet gun hunting squirrels, but anyway so I skin it get the fat off with salt then scrape off the salt and its permanently good right?? or wrong?? And I dont have the need or hope to tan them.
Jan 1, 2009. 9:47 AMevanthehunter says:
hmmm, im wondering that too. I heard that some people rub eggs mixed in water into the skin to tan them. ill try it on my squirrel once its done drying
Feb 2, 2009. 3:53 PMtgeary00 says:
After step 4, do you rinse the plets off, then put them into the solution of alcohol. Do you scrape off the salt? Then put them in the alcohol? Very nice instruction and photos. I need a hobby and see these guys on the road all the time. I figure it will not be an expensive hobby.
Jun 3, 2009. 8:11 PMHuray4Insanity says:
could you try a nutira?
Oct 29, 2009. 7:15 AM3-4-t says:
I think this is great.  If someone is going hunting for food one should make use of all parts of the animal.  I believe we can be too touchy about those who just 'trophy hunt' and I think they should be regulated to do something constructive with the meat, I think folks should be congratulated for using every part - even the -..gasp- fur!!
1-40 of 72next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:cemetz
