Parts List
- 2 x Cree XR-R Star LED (LEDSupply.com 2 x $8.49)
- 1 x 3023-D-100 Wired BuckPuck, 1000mA Output (LEDSupply.com $19.99)
- 1 Altoid Tin
- 1Minoura Mounting Bracket (for water bottle cages) (Nashbar.com $3.50)
- 1 Plastic 4 x AA battery holder (Radio Shack $1.50)
- 4 x AA rechargeable NiMH Batteries (multiple sources ~$7)
- Cree L2 6 degree optical lens (LEDSupply.com 2 x $2.00)
(others - solder, solder iron, 5/64 drill bit, drill, artic silver epoxy (preferred), LEDSupply.com )
Remove these ads by
Signing UpStep 1: Drill 4 holes in your Altoid tin
Drill 1 hole on each side, 1 for the wires to the LEDs and one hole to mount the dimmer switch which will control the LEDs.
Visit Our Store »
Go Pro Today »
Sorry for the long reply. Ledsupply,com offers buckpucks with and without the potentiometer. Model http://ledsupply.com/03023-d-e-1000p.php (newly raised to $19.99) comes with the potentiometer, model http://ledsupply.com/03023-d-e-1000.php (now $15.98) comes with the control wires for a potentiometer or resistor but none attached. Without a pot or resistor the buckpuck is full on. If you just want full on/off this would be simplest. The pot appears to be a standard 0-5k potentiometer allowing current control of the buckpuck, Mouser.com sells this for $1.38, partnumber 31JN305-F but i have not tried it (Digikey should work as well). For biking on trails with oncoming pedestrians and bikes, I wanted a simple high beam / low beam switch so I replaced the potentiometer with an on/off switch in series with a 360 ohm resistor. On = 360 ohms resistance across the gray and yellow buckpuck control wires = low beam, off=open = high beam. (To turn off, there is a second switch on the power to the buckpuck).
If you parallel the LEDs instead of wiring in series the answer is yes, The disadvantage is you are reducing the current and reducing each LED output. The star LEDs have 2 positive solder pads and 2 negative pads making parallel connections easy so you can experiment and find the optiminum configuration.
For LEDs in series like I show in step 3, the answer is no. The LEDs will not run. Two is the limit for 4.8 volts with a series connection. Most of these high power LEDs (Cree, Luxeon, etc.) need a threshold of 2.3 volts to run (but not more than 3.9 volts or they lose life quickly). So 4.8 / 2.3 = 2 LEDs maximum in series is the maximum for a 4.8 volt driven buckpuck.
Dealextreme sells drivers that both step voltage up and regulate current, allowing high power LEDs to work with one 1.2 volt battery. examples shown here;
http://www.dealextreme.com/details.dx/sku.15880
http://www.dealextreme.com/details.dx/sku.7302
http://www.dealextreme.com/details.dx/sku.4735
Or If you want to stick with the buckpuk but want more light, I recommend stepping up to a higher voltage battery pack. The 3023 buckpuck can handle up to 32 volts. Unfortunately more than 4 AAs is a tight fit in an Altoid tin and the run time of AAAs is just too short. An empty water bottle makes a good battery case, and the cordless drill packs work well too. The Dewalt 36 volt lithium is really only 10 cells yielding a nominal 32 volts and I have used it with a buckpuck and 12 luxeon LEDs. But in my opinion, 12 LEDs may be a bit too bright for oncoming traffic. Good luck.
http://www.ledsupply.com/02009-sho.php
http://www.ledsupply.com/bucktoot.php
I'm worrying that the min. input voltage for the buckpuck is 5V and 4 NiMHs don't quite add up to 5V. And I'm cheap...
Also Check out
http://www.dealextreme.com/details.dx/sku.7612
I share your concerns about the voltage of NiMH Batteries. Typical individual NiMH batteries fully charge to around 1.4 volts but drop to 1.2 volt. And of course 1.2x4 is only 4.8 volts. The buckpuck states the minimum voltage as 5 volts but mine appears to still work at a little lower voltage ~4.6 to 4.7 volts. (But I'm also very cheap as well. The micropuck listed first may not be able to drive multiple high power LEDs and the bucktoot in your second link States the same 5 volt minimum as the Duckpuck. My Altoids Version2.0 will likely use either a single LED with a single Deal extreme driver or multiple Drivers with one LED per driver. I really like the Dealextreme prices.
Hope this is more complete then the abbreviations above;
White Cree Q4 XR-E Star at http://www.ledsupply.com/creexre.php, note that these are rated 100 lumen at 350 mA, but I drove them at 1000 mA with the buckpuck below,
3023-D-E-XXXP: 1000mA Constant Current Output, External Dimming w/ pot. The pot appears to be a standard 0-5k potentiometer allowing current control of the buckpuck. ( note - An option to save $4.00 and possibly improve the control is to buy the same device without the potentiometer 3023-D-E-XXXX: and control with a 3 way switch, open or wires unattached = full-on 1,000 mA, with a 5k resistance = full off, and ~360 ohm resistor = 100 mA which in my opinion is a nice be seen light / low beam option). Or in other Instructables find your own "how-to" build your own circuit control for LEDs and eliminate the buckpuck entirely. Your mileage may vary.
