3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Curiously Strong Bike Light - 400 lumen Cree LED ALTOIDS
Build a 400 lumen bike light in an Altoid tin for ~$50. The new incredibly bright, high efficiency LEDs by Cree, the Cree XR-E are simple to wire and are relatively cheap. Drawing very little power but able to output 100 lumen each at 350 milliamps and an incredible 200+ lumens each at 1000 milliamps these little LEDs are at least 30% brighter than last years best Luxeon LEDs. Power for 2 or more hours with 4 AA NiMH rechargeable batteries. Everything tucks neatly into an Altoids tin. Ride bright and never fear the dark again.
Parts List
- 2 x Cree XR-R Star LED (LEDSupply.com 2 x $8.49)
- 1 x 3023-D-100 Wired BuckPuck, 1000mA Output (LEDSupply.com $19.99)
- 1 Altoid Tin
- 1Minoura Mounting Bracket (for water bottle cages) (Nashbar.com $3.50)
- 1 Plastic 4 x AA battery holder (Radio Shack $1.50)
- 4 x AA rechargeable NiMH Batteries (multiple sources ~$7)
- Cree L2 6 degree optical lens (LEDSupply.com 2 x $2.00)
(others - solder, solder iron, 5/64 drill bit, drill, artic silver epoxy (preferred), LEDSupply.com )
Step 1Drill 4 holes in your Altoid tin
Drill 2 holes in the bottom of the tin to mount the bracket which will hold the tin to your handle bars.
Drill 1 hole on each side, 1 for the wires to the LEDs and one hole to mount the dimmer switch which will control the LEDs.
35 comments
Nov 26, 2011. 11:19 PMmtaylor22 says:
Thanks a lot. I have been looking around at home-made lights and wondered what a "buckpuck" was as it was mentioned in some forums. I thought of using a guitar pot. switch but figured it probably would be the wrong sensitivity, and cheap ones are staticky. Great find. How do you feel about the LEDs with no reflector on them? Looks like it works ok, though. Good job.
May 7, 2010. 1:42 PMpteranosaur says:
Me thinks you say-use the paralell connection for 4 batteries(6vdc),for higher voltage,use series connect...Will not the paralell connection only give 1.5vdc ?!
Nov 26, 2011. 11:16 PMmtaylor22 says:
He surely means the LEDs are connected in series or parallel, in the above post, as shown. The batteries are of course in series.
Oct 1, 2011. 5:50 PMeterzi says:
I got the the 3023 D-N-1000 on accident... will this be ok?
Jul 20, 2010. 11:53 AMEntropy512 says:
Running LEDs in parallel without individual current limiting for each series strand (in this case, your series strands are just single LEDs) is a bad idea - If one LED fails or disconnects, the other LED will receive all of the current and be overdriven. LuxDrive also sells the BoostPuck, which would allow you to drive a 2-series LED array from 4xAA.
Apr 14, 2009. 5:32 PMlolzertank says:
Doesn't the buckpuck require a higher input voltage than its output voltage? So even though the buckpuck can operate from 5 volts or possibly a little less, your leds have a forward voltage of 3.7V each at 1000ma for a total of 7.4V since they're in series. With each led getting less than 2.5V, there is no way they are operating even near 350ma, much less 1000.
Mar 29, 2010. 8:17 PMswamp_yankee says:
Read the datasheet. As you say it can operate down to 5V, but the output is a current (as specified in the part #) and the voltage can exceed the input voltage, up to a max of 32V. This is known as a "boost converter". Current drawn from the lower voltage input is higher than the current to the higher voltage output. Go to zetex.com and look at the datasheet for ZXSC300 or ZXSC310 for actual schematics of how this works.
Sep 27, 2009. 5:23 PMoutfieldman says:
I just finished soldering up everything, and I have two quesions. first, it seems that the lens needs to sit flush against the led for proper placement of the light, but the solder is in the way of letting the lens sit flush to the light??? Also, the light really isn't very bright; both bulbs are on, but the dimmer really just works as an on-off, and its not that bright. Thanks for any help on this...
Sep 27, 2009. 7:58 PMoutfieldman says:
Thanks. Would it be possible for you to add a schematic or photo as I don't know anything about wiring. Thanks!
Sep 29, 2009. 10:13 AMoutfieldman says:
Wow, it works great. Thanks.
Dec 29, 2008. 8:01 PMhammertong says:
Does the dimmer come with the buckpuck? What potentiometer would you recommend?
Jan 5, 2009. 9:53 PMhammertong says:
I just got my shipment from LEDsupply today and was glad to see the dimmer switch prewired. I then soldered everything together and thought my rechargable AA's were dead, then realized I put the jumper wire on the wrong polarities. + in & + out to - in & - out. I swapped it and the light works great. Great Instructable, awesome (and simple) design. Thank you!
Nov 19, 2008. 11:12 AMgoodgnus says:
Interesting... I wonder what kind of heat those babies generate and if you maybe should have had some intermediate heatsink between the LED's and tin. How hot does the tin get around the LED's after it's been running for some time?
Nov 21, 2008. 6:30 AMclark says:
when i went to radioshack a few weeks ago they told me they didn't have themistors! where did you find it?
Jan 6, 2009. 2:14 PMclark says:
i got one at mouser, it worked for what im using it for.
Nov 19, 2008. 8:38 PMQuiksilverRox says:
I thought LEDs don't produce heat, just light.
Nov 20, 2008. 8:02 PMjmengel says:
As "goodgnus" says, the heat is still significant. It just shows how inefficient the incandescents are. If a typical incandescent is 2% efficient in terms of visible output (~12 lumens/watt), then a 100W bulb puts out 98W as heat (Easy Bake oven brownies anyone?) and other wavelengths. The best LEDs are in the range of 120 lumens/watt, which is roughly 10x the efficiency of an incandescent or 20% luminous efficacy. So a 3W LED still puts out about 2.4 watts of heat and other waste wavelengths. This need to be dissipated to keep junction temp down and luminous efficiency and lifetime up. So, yes LEDs output a lot more light compared to incandescents, but the heat output still dominates.
Nov 19, 2008. 10:19 PMgoodgnus says:
LOL. I do suppose we all start at 0,0. Led's certainly produce heat. At low power it is less detectable and certainly less heat than a comparable incandescent would generate. However, todays high power led's produce significant heat.
Dec 29, 2008. 6:13 PMmalkari says:
yea its brill,be nice to see the wires a bit better from the battery and petentiometer to buckpuck.
Dec 7, 2008. 2:39 PMszaballos says:
Can you run more than two Cree's off this buckpuck while connected to the 4.8v source?
Nov 26, 2008. 6:16 PMLedgehanger says:
Would you please forgive my ignorance and answer a simple question for me? When soldering the AA battery holder to the buckpuck, does it just require attaching black to black and red to red? Thanks.
Nov 24, 2008. 10:52 PMkrupan says:
Any thoughts on whether one of the smaller cheaper LED drivers would work?
http://www.ledsupply.com/02009-sho.php
http://www.ledsupply.com/bucktoot.php
I'm worrying that the min. input voltage for the buckpuck is 5V and 4 NiMHs don't quite add up to 5V. And I'm cheap...
Nov 20, 2008. 11:22 PMsarubin says:
Great fabrication. Could you please check the name/spec of the Cree lights and buck puck listed on the front page? They are different than that available at LEDSupply and different from what you state in the next steps.
Nov 21, 2008. 6:34 AMheavypiece says:
Dude...that is such a cool set-up... 400 lumen from an Altoid tin. Great idea.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:pobriant
