Step 1: Supplies
1/4" ribbon
1/4" wooden dowels
small binder clips
hair clip
glue gun
strong thread
If you want to use wider or narrower ribbon, you may want to experiment with different sized dowels. Grosgrain ribbon can also be used and looks really cute. I generally use upholstery thread, but you could even use dental floss if you want.
Step 2: Wrap your dowel with ribbon
Step 3: Baking your ribbon
Continue wrapping dowels until you have several. Set them on a cookie sheet and bake at 250 degrees for about twenty minutes. Let them cool completely.
Step 5: Cutting
Cut the ribbons into desired length. These pieces are about four inches long and since I want the bows fairly full, I've used six dowels worth of ribbon.
ETA: Depending on the type of ribbon you use, you may need to seal the ends to prevent fraying. Acrylic ribbon can be sealed by holding the cut end near a flame briefly until it melts very slightly, or dab the ends with Fray Check. Some ribbons may be just fine if you cut at a 45 degree angle.
Step 6: Tying
Gather the thread tightly and tie a good, secure knot. Wrap it around one more time and tie it again.
Step 7: Finishing
Once the glue has set, flip it over and trim the ends if you'd like to clean it up a bit.
Now go make a little girl happy!
Visit Our Store »
Go Pro Today »
no idea how easy it is.
Thank you thank you....you've opened a new crafting avenue for me!
The baking of the ribbon sets the curls. It's similar to using a curling iron on your hair - the heat sets it in.
I wouldn't recommend using the microwave for curling your ribbons as the microwave heats unevenly. There is a certain point at which the ribbon will just start melting.
I hope that helps! Good luck!
This is absolutely wonderful. I've been paying a fortune for tiney little bows such as these and I so wanted to make my own using colors I love! This is PERFECT. Thanks so much for sharing!
I usually buy my clips (like the ones in the photos) at the craft store. They're usually near the beading section.
I have also used ribbon covered alligator clips. You can buy boxes or small pkgs of alligator clips at most beauty supply stores. I use the instructions here to cover them: (you may have to sign up to access the forum, but it's free and very helpful!) http://www.hipgirlclips.com/store/index.php?main_page=document_general_info&cPath=31&products_id=1457
I hope that answered your question, but let me know if you need anything else!
Thanks!
Thanks
