Remove these ads by
Signing UpStep 1Supplies
1/4" ribbon
1/4" wooden dowels
small binder clips
hair clip
glue gun
strong thread
If you want to use wider or narrower ribbon, you may want to experiment with different sized dowels. Grosgrain ribbon can also be used and looks really cute. I generally use upholstery thread, but you could even use dental floss if you want.
The baking of the ribbon sets the curls. It's similar to using a curling iron on your hair - the heat sets it in.
I wouldn't recommend using the microwave for curling your ribbons as the microwave heats unevenly. There is a certain point at which the ribbon will just start melting.
I hope that helps! Good luck!
This is absolutely wonderful. I've been paying a fortune for tiney little bows such as these and I so wanted to make my own using colors I love! This is PERFECT. Thanks so much for sharing!
I usually buy my clips (like the ones in the photos) at the craft store. They're usually near the beading section.
I have also used ribbon covered alligator clips. You can buy boxes or small pkgs of alligator clips at most beauty supply stores. I use the instructions here to cover them: (you may have to sign up to access the forum, but it's free and very helpful!) http://www.hipgirlclips.com/store/index.php?main_page=document_general_info&cPath=31&products_id=1457
I hope that answered your question, but let me know if you need anything else!
Thanks!
Thanks
