3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Current method for Photovoltaic Calculations
Hi everyone!
This is my firs attempt to make an Instructable, being a huge fan of this site, I am pretty excited.
I am from Argentina, so it is probable that some misspellings and grammatical errors pop up here an there, I apologize in advance for them.
Current Method for Stand Alone Photovoltaic Systems Sizing
This particular method is known as "Current method" since it uses the currents (in Amps, Amps Hour / Day) to select the components.
The components:
1) The modules
In Argentina we use this scale: cell → Module → PanelThe PANEL is an array of several modules, plugged in series or parallels to achieve the right configuration. In this example we will have everything in 12 V systems, so 32-cells modules are going to be OK.
The MODULE is composed of several cells in series and parallel to achieve the right current and voltage.The CELL is the smaller component. Is made of silicon, with the electric contacts in front and rear to pick up some electrons, running around the silicon when some photons hits them.
2) The charge regulator
This is a critic component, since it keeps your batteries fresh and healthier. A bad chosed charge regulator will end up in an early death of the batteries.
3) The battery bank
Deep cycle solar batteries aren't cheap, nor light weight. So choosing the right size of that battery bank, suitable for your budget and energy needs is going to be criticall.
Hope someone finds this text helpful!
Lets begin!
Step 1Basic Knowledge
Basic Knowledge
Ok, let's start with the basic knowledge.
You will need to know here that some skills on the electric field are required. Not much, but some really helps.
One thing you will found very often is:
Power = Current x Voltage
Power in Wats [W]
Current in Amps [A]
Voltage in Volts [V]
We are going to need an “Isolation” or “Irradiance” chart of the area where we are located, to calculate the average monthly energy that reaches our module every day.
In Argentina we have some charts, and tables with measured Irradiance at several angles. This is really helpful. But in fact, we use the “Peak Sun Hours” wich means the equivalent in hours at 1000 W m^2 / day (a constant known as 1 SUN).
You probably found your Irradiance charts or tables in Kw (Kilowatts = 1000 Wats) or MJ (Mega Joules).
If you have them in Kilowats, you are lucky, so there is no need to make any change or calculation. But if you have them in Megajoules, you will have to divide that number by 3,6 (we use comma as decimal separator. Take notice of this) to convert that unit to Kw.
So lets recap:
W = A x V
MJ / 3,6 = Peak Hours (HSP) in further formulas referred as "H"
The full formula looks like this:
1 HSP = [(1000 W x 1 h ) / m2] x [3600 s / 1 h] x [1 J/s / 1 W] = 3,6 MJ/m2
23 comments
Feb 9, 2012. 2:16 PMAjiero says:
Dear Supernatural, my name is Ikenna Ajiero, a Master's Degree student. I have a task, and in a bid to source the requisite information, I ran into your profile online, through you website on this link:
http://www.instructables.com/id/Current-method-for-Photovoltaic-Calculations/
My Task is part of my coursework and in all truth I am completely naive of the rudiments, as we have not been taught a single thing on how to do a similar work, so I most heartily seek your assistance.
I really need to learn the procedure, as well as excel in this course work, that is why in confidence that you can solve this problem, I most heartily entreat you to help me design one or put me through how I can go about it.
Could you help?
Thanks in anticipation.
My email is nonstop4heaven@yahoo.com
This is the task:
Renewable Energy Technologies Task
Objectives
• To identify and assess the scale of renewable energy resources;
• To use appropriate techniques to assess the feasibility of renewable energy resources, and
• To use appropriate software to help assess renewable energy systems.
The task
You have been asked to investigate the potential for renewable energy for a small dwelling in the Scottish Highlands. The owner, a writer, plans to refurbish it and use it mainly as a retreat up to four weeks at a time, to ‘get away from it all’ so that he can concentrate on his writing. He envisages occasional weekend visits by friends, up to four people at a time, and expects that the total use will be about six months per year.
The house could be connected to the electricity grid, but connection is expensive, and the unit price of electricity will be high. Therefore the owner wants to know whether it might be possible to develop a stand-alone renewable energy system to provide for his needs.
You should consider the energy requirements for the dwelling (heating, lighting, cooking, etc.) for a single person, with occasional use by up to four people, as described above. Write a report for the owner which to outline the technical possibilities for a renewable energy system for the dwelling.
You are required to:
a) Outline briefly a possible energy strategy for this building. For each of the available renewable energy resources, estimate the size of the resource (see below for data), discuss the characteristics (whether it can provide heat or electricity (or both), seasonal variability, storage requirements, etc.), and hence determine which resources are most likely to be most useful for this application (say, 800 words, 25% of the marks).
b) Analyse the heating or electricity requirements for the house in some detail, and, considering one of your principal energy sources identified in (a) above, discuss in detail how you think it could be incorporated into your plans (say, 1000 words, 30% of the marks). Note: for a ‘real’ report, you would normally expect to analyse the all the energy requirements and all the potential energy resources – this full analysis is not required for the purposes of this coursework.
c) Use the RETScreen software to analyse the contribution that your chosen energy resource (from (b) above) could provide. Write a commentary on the most important features of your analysis (45% of the marks).
Note that this is principally a technical exercise and you are not required to investigate financial details, but the costs of any scheme should fall within ‘reasonable’ limits. The primary function is to provide for the energy requirements of the dwelling, and not to generate heat to electricity for export, or to act as a test-bed for experimental technologies. This means that the scale of your scheme and the technologies used should be in keeping with the size of the dwelling and its requirements.
Data
Use the following data. You may also seek out other sources of weather data. Make reasonable estimates and assumptions for any information not given, but make sure that you state clearly any estimates and assumptions you make. You may work in MJ or kWh, but you should ensure that the report is written using consistent units.
• The house is in an unspecified location in the Scottish Highlands. You may assume that the principal sources of renewable energy are: solar, wind, hydro and woodfuel, as given below.
• The house has a plan area of 45m2, with the main façade facing almost due South. After applying insulation, double-glazing and draught-stripping, the building will have an overall heat loss coefficient of 160 W/°C, i.e., for every °C temperature difference between the inside and outside, the heat lost will be 160W.
• Weather data may be accessed via the RETScreen software. Note: the wind data given in RETScreen for Scotland is low – you may use a mean average windspeed of 7.2 m/s.
• You may assume that the owner of the house has access to 1.5 hectares of woodland, which can provide 6m3 of timber per hectare per year, with a calorific value of 11 GJ/m3.
• The house has access to a small hillside burn, with a catchment area of 0.8 km2. It may be possible to make use of a fall of about 8m to provide a source for hydroelectric generation.
Marking criteria
You are expected to:
• outline the relative size, characteristics and usefulness of the available resources;
• generate a specification of energy requirements;
• choose, and justify your choice of, a principal energy system for supplying the perceived requirements;
• use the RETScreen software to size a renewable energy system, including storage requirements;
• discuss the validity of your analysis and your assumptions.
A mark of 55% - 65% will be awarded for a report which addresses the above points and appears to be largely correct in its calculations.
A mark of over 70% will be awarded for a piece of work which demonstrates an in-depth understanding of the issues involved, perhaps by incorporating more than one energy resource, or by assessing and comparing more than one alternative system.
A mark of less than 50% will be awarded for a piece of work which shows only a basic understanding of the problem, has significant errors in the calculations and makes unwarranted or unreasonable assumptions.
In particular, note that the software part of the assignment is valued at 45% of the total marks. Therefore it is imperative that you work to understand how to use the software, and make sure that the data input matches your own calculations, and that your commentary discusses the results in the context of your own estimates.
Note on referencing and presentation: You are required to cite references for your work. Although the coursework will be marked on content, and no mark is given specifically for references or presentation, where poor presentation is detrimental to understanding your work, or where references are clearly missing, marks may be deducted (up to 10 marks in extreme cases). Equally, where presentation particularly helps the understanding of the work, additional marks may be awarded. However, it will be rare for a mark to be increased above 70% or decreased below 40% principally on the basis of its physical presentation.
Feb 17, 2012. 9:24 AMAjiero says:
Dear Supernatural,
I am really grateful, i have seen it, its a whole lot of work you did, i will apply your directive accordingly, and will get back to you if need be, or when I am through.
Meanwhile, thanks a lot for your time and seasoned intellectual resources.
Ajiero, Ikenna Reginald
Feb 17, 2012. 1:15 PMAjiero says:
Thanks Supernatural. Keep this act of kindness up, and God will continue to bless you.
Many thanks.
Ajiero, Ikenna R.
Jul 8, 2011. 7:06 AMtbone56 says:
Good job. You put it all together. Just what I needed.
Thanks.
Feb 5, 2012. 8:05 PMEliseosebas says:
Dear Supernatural. Today is 5th february 2012. Nobody know your method. Have wrote on other paper?
Please let us know your method!
Aug 8, 2011. 9:15 PMibarnett52 says:
GREAT INSTRUTABLE
Jun 22, 2011. 8:23 AMNightLord says:
"MJ / 3,6 = Kw"
Noupt, actually 3,6MJ = 1kWh (not kW!).
Jun 22, 2011. 10:21 PMNightLord says:
Sorry for such "agressive" comment, your article is still great and I knoy you've put a lot of work into it. I wasn't in a really good mood when I wrote it ;).
I just really don't like confusion between kW and kWh, because this is really common and nobody understands even so simply physics as difference between energy and power, and I didn't really check your formula in details, to see what you were really calculating. Sorry again.
Jun 22, 2011. 4:26 AMnanosec12 says:
Supernatural,
A couple of suggestions, since this is your first instructable:
1. Your English, while not perfect, is good enough to convey your message and is much better than most of our spanish. Muy Bueno.
2. I think it would help if you could add an english translation to all of the photo captions, either yourself or with help from others. Some of the captions are already written with both english and spanish, but a few are not.
Thank you for your effort, with this instructable and with your english write up.
May 16, 2011. 3:51 PMkelseymh says:
This is a nice writeup, with decent guidance for the beginner on how to deal with medium-scale solar installations. I do have some minor comments on your units, though.
Joules are a unit of energy; watts are a unit of power, which is energy divided by time. When you write, "MJ/3,6 = kW", you really should write, "MJ / 3.6 [1000 s] = kW", since you have to divide joules by seconds to get watts.
I'm confused by your irradiance explanation. "1 kW m2/day" appears to have too many units of time in the denominator.
The SI symbol for "kilo" is "k" in lower case, not "K".
I'm a little confused by your Ohm's law calculation. You write "V = 2 x Length (in meters) x Current (in amps) x Cable Resistance (on Ω/meters)". Obviously length × resistivity is just resistance, so you get V = IR. But where does the extra factor of two arise? You don't need to deal with the return cable from the load back to the solar panel.
May 16, 2011. 8:55 PMkelseymh says:
Muchas gracias, Pablo. Mi lengua primera esta ingles, y mi espanol esta pobre.
I am very grateful that you will take the time to work through the English for me, and I am sorry that I don't know enough Spanish to properly return the favor.
Have you communicated with any of our other Spanish-speaking members? A few of the ones I know are Rimar2000, ricardoruizo, M.C.Langer, but there are many others. There's also a discussion group where members interested in multilingual or non-English I'bles have some topics going.
I am a physicist, so for me the units are very important. I appreciate wanting to keep things simple (and thank you for clarifying that you made deliberate decisions, not mistakes! :-), but my own training and teaching of students suggests that with proper units, you can tell quickly if you have the wrong formula (the units don't work out correctly).
I still think the factor of two in your resistance calculation is wrong. Here's why: What you're computing is the voltage drop from the output of your solar panel to your load. That's V = I×L×r (here r = resistivity, ohm/m). The load itself will introduce some additional voltage drop due to its own resistance (or impedance). The return path is necessarily dropping all the way to ground (by construction), so the voltage drop due to the return cable is irrelevant.
You can also think of it this way. You could set up your system with just an outgoing cable! Connect the negative side of the solar panel to a true earth ground, run a single wire from the panel to your load, and connect your load to a true earth ground at its location. The current flow will be earth -> panel -> load -> earth, with the two (possibly distant) earth locations connected implicitly by dirt, ground water, whatever.
Jun 22, 2011. 3:55 AMscraptopower says:
I'm not sure about the voltage drop point of view, but the return leg resistance is just as important to keep low as the other side of the circuit as all of the current charging the battery must flow through it.
I don't think your earth example would work as there would be too much resistance from the ground/earth/soil water, so almost no current would flow.
Jun 22, 2011. 2:43 AMcmac91000 says:
Hi, I am currently investigating how to install Solar power in my home to supplement the mains supply. If you are a complete novice then this can be quite confusing.
I would like to say that this instructable is probably the easiest one I have come across to date. I congratulate you on your easy to understand expainations.
Thanks for your help, it has given me the confidence to go ahead with my project.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Supernatural(Instalaciones)
