loading
Step 9: Curtain tape - gathering
The curtain tape now needs to be pulled to gather the curtains. Each piece of tape has two strings running through it - at one end, pull the strings a little bit, and tie them together.
At the other end, pull the strings out, tie them together, and keep pulling. Distribute the curtain material evenly so it's not bunched up at just one spot, until the curtain is the width that you want it - don't make them too narrow or they won't close all the way. Tie the other end off with a loop, so that you can adjust later if necessary.
I am making my blackout curtains asap I feel like people are watching me at night! Well , only in one room. THE BEDROOM.
Really?<br><br>Or are you advertising your commercial website?
There's an easy way to change the thread to a different colour, but it only works if it's already threaded.<br><br>You cut the thread that's already threaded at the top of the sewing machine, then tie your new colour to the piece that's already threaded, place the new spool in place and pull the old thread through from behind the needle (or however the needle is threaded), you'll pull the entirely new colour through the mechanism and it'll thread itself. Quick timesaver :D
True, although you don't want the knot to become caught in the mechanism.
There is that. I suppose you just have to make it tight enough :) Wouldn't work for all sewing machines and needles but I figured I'd put it out there :)
the same can be done with a sheet.
Nice Job!! Being the lazy sort who likes to do it the fast way--I never bother with the curtain tape. If you make your top hem the right width the curtain rod slips through it and you don't have to bother with all that--plus it's nicely gathered and fits closer to the wall to block light. You also might want to shorten your bottom hem to where it's just off the window sill. In some weather windows will have condensation and it will run down onto your hem there with unpleasant results. It will also have a tendency to get dragged into whatever is on your sill if it's too long. An extra quick curtain if you are in a hurry for coverage is bed sheets. Get them at a thrift store and either fold them over the rod or cut to fit the window and hem the sides. They have ready made hems on the top and bottom! They will block a lot of light and vision, but if you're worried about someone seeing in you can add another for a nice decorator effect.
The bottom is a little low - it's not hemmed. (closed seam, no need) I might put a hem in at some stage, but for now it works nicely. My biggest issue is the dish-washing things on the sill.
Check out this link for storage and stuff :)<br/>&lt;img src=&quot;http://www.organizeit-online.com/images/757.jpg&quot; alt=&quot;Suction Shelf&quot;&gt;<br/><a rel="nofollow" href="http://www.organizeit-online.com/suction-corner-shelf-p-900.html?currency=USD&amp;language=en">SuctionShelf</a><br/>I have these and am extremely happy with the results. (no drilling n stuff)<br/>
You could try safety pinning the hem up as a temporary measure--put the pins in the back and space the front to be decorative. That way your hem will be already pinned in place when you feel like finishing it. Or the really lazy is use a strip of iron in web interfacing. Not a good permanent solution but okay for a quick fix!
About This Instructable
53,570views
65favorites
License:
More by MrTrick:Broken "Quick-Grip" Quick Fix Star Map LED Christmas Tree
Add instructable to:
