3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom 3D Settlers of Catan board from scrap plywood
Step 7Cut base
Cut base
I wanted a circular base, so I roughly cut this out of the side of a plywood box; it happened to be 3/8" thick (9 mm). I then nibbled the outside off using my bench saw (see pictures), so that the circle was perfect. Then I sanded off the stickers, stopped the holes and smoothed the edges.
2 comments
May 21, 2010. 3:44 PMlewisb42 says:
 I've had good luck cutting circles using my router and a homemade circle jig.  I start by cutting them rough with the jigsaw (similar to what you did), then running my router (with a 3/4 straight bit) around the edge to smooth it.  As long as the "waste" left over from the saw cut is less then the diameter of the bit it works quite well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
212
Author:makendo
I'm probably off making something. Most likely a sandwich.
