3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom Acrylic Chess Board
I've always had a soft side towards chess sets.  I've never been particularly good at chess (I know how the pieces move and I know when I'm about to be destroyed, but that's about it).  I have, however, always enjoyed the artistry and design possibilities inherit in a good chess set.  It was The Shawshank Redemption that made me realize that you could make a chess set out of just about anything, and it was a month or so ago when I realized that I wanted a chess set of my own design.  Acrylic (also known as plexiglass) would be my medium and a laser cutter (generously provided for my use by MIT) would be my weapon.
The board is three layers of acrylic thick, the pieces are between 14 and 27 layers thick, and in the end you'll have a sturdy, scratch-free, and totally hand-made (laser made?) chess set!
This Instructable will walk you through
a)  What materials I used and where to get them for the best price
b)  How I went about designing the board and pieces
c)  The assembly process
and throughout the Instructable will be, what turned out to be vital, tidbits of information that, through trial and error, I've figured out so you don't have to.  I was fortunate enough to have access to a laser so I could make multiple cuts and try different approaches.  But that's not always possible (especially if you're ordering laser cut parts online), so my aim is to provide you with the information you'll need if you order your parts online.
Step 1What You'll Need
What You\
Material (~$90 with shipping)
2 Acrylic Sheets (for the colored squares)  - 12" x 12" x 0.236" - McMaster
2 Acrylic Sheets (for the pieces) - 12" x 24" x 0.118" - McMaster
1 Acrylic Sheet (for the trim) - 12" x 24" x 0.246" - McMaster
1 Acrylic Sheet (for the bottom plate) - 17" x 17" x 0.125" - TAP Plastics
1 Scratch Resistant Acrylic Sheet (for the top plate) - 17" x 17" x 0.125" - TAP Plastics
2 Acrylic Rods (for the pieces) - 0.125" diameter, 6' long - McMaster #8531K11
1 Box of Screws (to screw board together) - 6-32, 0.5" long - McMaster #92949A148
Rubber feet (for bottom of board) - McMaster #95495K66
Tools
6-32 Tap - McMaster #8321A63
#36 Drill Bit - McMaster #30585A49
Drill
Allen Key - 5/64" - McMaster #7122A55
TAP Acrylic Cement (smaller can) - TAP Plastics
Hypo Applicator (for acrylic cement) - BD-25/2 - TAP Plastics
Optional
Cotton Archival Gloves (available on McMaster)
Microfiber Cloth
Materials for Pegboard (detailed later in Step Five)
20 comments
Jan 3, 2011. 2:36 PMcraftyv says:
Brilliant. Very attactive and certainly has the wow factor. Well done with the ible it's great.
Jan 3, 2011. 3:38 PMmousetraps says:
This is awesome!
Jan 4, 2011. 9:42 AMrammstein2 says:
the set is badasssss...........!!! and the MIT logo makes it even more so (wish i was an MITian :'( )
Jan 11, 2011. 2:16 PMsoeinegaudi says:
awesome !
really impressive photos
Jan 12, 2011. 6:55 PMmarshavoc813 says:
I really love the set! If I may offer a suggestion though, attach a piece of felt to the bottom of the pieces. This helps them glide across the board and will keep the edges of the pieces scratching the surface of it as well. Just my $0.02.
Again, very nice!
Jan 13, 2011. 6:14 AMbmohr says:
Fantastic imagination AND execution. Thanks for sending including all the gotcha's. That makes it a great instructable IMHO.
Jan 13, 2011. 7:55 AMnanosec12 says:
Wow, what a great instructible.
I for one am in your camp, I have always been fascinated with a great looking chess set, and have often thought of building or buying one of the nice themed sets (Star Wars comes to mind), but although I do know how to play, I also do not play well.
good Job
Jan 13, 2011. 8:01 PMhjfast says:
Well done. If you want to avoid the "blackening" of the acrylic with the paper removed, try a higher speed (20-30%). You might not cut through in one pass, but you also won't char the acrylic. Rubbing alcohol also does a pretty good job of removing the black if you use it immediately.
I think I will have to make one of these before I graduate and lose access to our laser cutters.
Jan 14, 2011. 7:48 AMWicken says:
This is so beautiful! Great work and wonderful 'Ible.
As a side note, while I can see why you'd have second thoughts about it I really like the look of the columns seen through the clear pieces. (And not just because they look like tiny models of futuristic buildings.)
Dec 5, 2011. 5:35 PMojitodeuva says:
Hi!, I loved your design. I tried to open de excell spreadsheet with several programs, but nothing worked..
Would you help me? How do you open a spreadsheet?
Thanks for your time
And congrats for your project! :)
Dec 5, 2011. 5:32 PMojitodeuva says:
Hi,
I love your design, I tried to read de excell spreadsheet with several programas, but I couldn't...
Would you help me? how do you open a spreadsheet?
Thank you for your time :)
Jan 27, 2011. 12:16 AMKollapce13 says:
This is awesome, my game
Jan 19, 2011. 10:41 PMshigun says:
Nice job! I would have bought such chess ...
Jan 19, 2011. 10:44 AMXm3buX says:
I know this may be asking too much, but would you be able to upload your SolidWorks files? I tried designing the pieces myself, but as I've only successfully used SolidWorks once before (for something very simple), I messed it up quite badly...
If not, I understand.
Thanks for the awesome instructable :D
Jan 16, 2011. 7:24 PMlolo_vago says:
a duck? :P
Jan 16, 2011. 12:59 PMtwighahn says:
i think ill make some wooden chess pieces one side will be chickens and tthe other side will be monkeys to celebrate the chinese zodiac
Jan 16, 2011. 10:42 AMdreamtimegypsy says:
Ripper cober, intend to make one of these one day. To cut the clear acrylic, I made a raised bed, with tiny tables of clear acrylic to sit the sheet on, this way I can remove the sheet at will and replace it in the exact same position every time, still with drawing loaded and saved on pc. No burning marks this way. Hooroo from downunder.
Jan 14, 2011. 3:11 PMK.hall86 says:
Truly beautiful! I do not have a machine like that at my disposal, but i was thinking of making the pieces on a CNC machine out of billet brass and aluminum. One concept that I find really neat is engraved acrylic and LEDs. if properly placed, the LED will cause only the engraved portion to light up.
For Example, http://www.instructables.com/id/Make-Your-Own-LED-Wedding-Table-Cards/ by JerseyJ
I am very impressed with the complexity and quality...GREAT JOB!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:jzzsxm
