3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom Belt Buckle
Custom Belt Buckle
How to take your own pictures/designs and put them into a rad belt buckle.
Tools you'll need:
Casting Resin
Catalyst
Clear tape
Scissors
Mixing bowl & mixing tool
Blank belt buckle
Step 1Tool time
Tool time
First, get all your tools together for easy access.
Measure your belt buckle, for picture sizing. (Mine ended up being 2in x 2 3/4in)
8 comments
Jul 21, 2010. 6:02 PMTechDante says:
http://www.tandyleatherfactory.com/home/department/Buckles/Buckle-Making-Supplies/11739-01.aspx?feature=Product_19
this is the company used by jenifer bryan for teh belt buckle from Make: issue 22
Jan 26, 2010. 3:09 PMPhallicWorship says:
 An alternative to taping the picture is to coat the image with one or two layers of Mod Podge (It's a glue, seal and finish). Cover the image on the front and the back, let it dry, and put on another coat to be safe. Mod Podge is fairly inexpensive. It seals the ink in and the resin out more effectively than the tape does.
Hope this helps. :)
Jan 15, 2010. 10:36 AMjansim says:
Even though I laminated the picture with clear tape (front and back), the resin still leaks in from the sides and "stains" the picture.  Any suggestions on how to prevent this?
Jan 15, 2010. 10:34 AMjansim says:
I found that if you run a hair dryer over the cast at a sideways angle, the bubbles come out really fast.  (Just watch that you don't "blow" your resin over the edge of your buckle).
Nov 24, 2009. 6:47 PMrussian5 says:
Did you put the buckle in a container when applying the resin or did you just pour it on?
Oct 31, 2009. 1:08 PMjansim says:
Just wondering where you purchased your belt buckle.  I have looked all over the net and can't seem to find this exact one.  Did you buy it at a store? Thanx!
Feb 26, 2009. 12:36 PMcrapflinger says:
any chance you've got make/model (for lack of a better term) on the resin product?
Feb 27, 2009. 1:31 PMKiteman says:
Check this image - the information is there for you already.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:inkdoll
