Custom Caliche Concrete Block
Introduction: Custom Caliche Concrete Block
This is a guide to making your own caliche concrete blocks. Caliche has been used for centuries as a readily available cement. Although it is much cheaper and in some places can be sourced from the building site, it remains less commonly used than the various cements that are sold. Using local caliche to make your own concrete blocks is cheap, eco-friendly, and creates a better connection between a building and where it is.
Step 1: Preparations
In places like Texas and New Mexico, caliche can be purchased very cheaply in bulk or excavated at the site. After spreading the material out on a tarp to let it dry out for a few days, it's time to sort it. Using 1/4" wire mesh sift through the material. The larger chunks of caliche can easily be crushed to maximize the usable material. Gloves and safety goggles should be used for the whole process.
Step 2: The Mix
The mix used for this example was:
9% Cement-Lime
55% Sand
36% Caliche
Step 3: Making the Block
Put the mix into a mixer, add water slowly and mix until the texture looks like a thick oatmeal. On a 4 mil plastic sheet Wet the mold and fill it with the mixed caliche concrete, shaking or tapping the mold slightly to fill the corners. Then remove the mold and repeat, wetting the mold every couple of times. Let the blocks cure out of direct sunlight or rain for a few days and after several more days they will be ready to move. Several days after that they should be ready for use.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    I have some questions please.
    I hadn't hird of caliche before and had to look it up.
    what are the advantages in using this. Is it lighter or stronger dose it last longer is it load bearing.
    Thanks for your interest!
    A key advantage is sourcing it locally and cheaply in certain locations. Caliche can be found in various locations around the world. For example in central Texas, where this project was based, caliche can be bought for cheaper than cement or simply dug on one's own property.
    You might want to check the commercial availability or natural presence of caliche in your area to decide if this makes sense as a building material for your project
    As for more detail on the structural characteristics and durability, you can read more about it here:
    I've seen a lot of people in TX use these for garden wall borders, they work well and look nice. :)
