3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom Candles
Custom Candles
I know there are plenty 'candle-making' instructables on here already, but most of them end with rather straightforward, standard shaped candles. With this instructable I will try to give some examples of what you can do with candles to make them original, and personal!
Besides this is my first instructable, so feel free to give advice for my next one!
Step 1Materials & tools
For making the candles:
- candle wax, or old candles you have lying around
- 2 cooking pots/pans for melting the wax
- candle wicks, or similar strings or cords (no plastic stuff)
For making the molds:
You can use a large variety of materials for the molds, but there are some things to remember when choosing a specific material. I will describe some that I have used.
- foamboard (foam inbetween 2 layers of thin smooth cardboard), is sturdy enough not to deform when you pour the wax. makes for smooth surfaces.
- thin cardboard, can be both smooth or rough, texture will reflect on the candle surface.
IMPORTANT! thin cardboard can bend inwards while the wax is cooling (and shrinking)!
- a hobby knife to cut the materials
- glue, hobby glue or any woodglue will do
- masking tape to hold the mold in place while the glue dries
18 comments
Aug 8, 2011. 4:14 PMkridley says:
i want to make a lego how would i do that???
Feb 21, 2012. 9:47 AMcekpi7 says:
make a mold of a lego and then pour wax in the mold
Aug 8, 2011. 4:25 PMkridley says:
how do you insert the metal heart ... do you need two wicks??
Feb 27, 2010. 2:25 PMbuteman says:
 I like these ideas. Thanks.
Would it help to smear some veg oil on the inside of the moulds so they would separate from the candle?
Mar 18, 2011. 4:29 PMrudegirl says:
i found olive oil helps but only with non absorbing materials. milk cartons are a good material for molds.
Dec 14, 2010. 10:46 AMTAE_Kim says:
Nice, now I should collect all the alien looking candles and try this. I wonder how it smells like with 5 different smells mixed. (bet its not gonna be bad tho)
Feb 27, 2010. 5:05 AMRavingMadStudios says:
Very cool. I especially like the one with the holes through it. I bet if you used short pieces of pvc pipe lubricated with a little vegetable oil, you'd have a much easier time demolding. Copper tubing might also work.
Jun 13, 2010. 7:44 PMjonjon192 says:
i think it would work but would the veg oil freeze?
Jun 13, 2010. 9:06 PMRavingMadStudios says:
I sincerely doubt that it would be a problem.
Jun 14, 2010. 12:04 PMjonjon192 says:
but it would if you live in places that get up to 35 below 0 ;) But I live in Georgia I doubt that would be a problew either
Feb 26, 2010. 5:36 PMkcls says:
Very cool! do you have any tips for getting that residue wax out of the bottom of jars?
Feb 27, 2010. 2:27 PMLaRue6358 says:
To remove wax from the bottom of glass jars, just put the jar in the freezer for about ten minutes.  The wax will then come out.
Feb 27, 2010. 12:49 PMclemsonguy1125 says:
 Try putting it in the freezer the just take a plastic knife and scrape it off
Feb 26, 2010. 9:47 AMRadBear says:
Very cool. You may want to give a little more detail on how to set-up the double boiler/two pot method for melting the wax. I know what you're talking about from having done some candle making in the past, but for those unfamiliar with this method it would be important to know as it relates to safety.
Overall great instructable. I look forward to seeing more in the future!
Feb 26, 2010. 11:52 AMBeanGolem says:
One thing I found making candles in my (earlier) childhood was that you must be careful not to end up making the wick travel too horizontally, as the flame "goes up" from its source and, in use, can extinguish itself with melted wax from above.
Just a thought :D Way cool end results you got! I love the wick coming out of the chimney.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:mrdebos(deBosDesign.nl)
