Step 3Tape the Torso
Wet each strip as you need it, because they dry fast and are extremely sticky when wet. To wet the glue, lightly run a damp (not sopping, just damp) rag or sponge over the shiny (glue) side of the tape. Do not put the tape under running water, as this usually causes too much glue to be washed off and it won't stick later.
Begin with a horizontal strip running around the midsection below the chest. Make sure that it is not too loose, we want the shape to be as close to the body as possible.
Next tape the chest and and shoulders, like making a harness. Use small pieces in all different directions over curvy parts, and try to keep them laying flat against the body. If you encounter a fold or wrinkle happening in the tape, you can notch it to keep it laying flat.
Lastly, tape around the stomach and lower back and neck area.
It helps if you tape symmetrically, so in the end all areas are evenly covered. Ultimately you need about 2-3 layers or tape to create a sturdy shell.
The tapee can help by cutting more tape or taping the front sections within reach. Try to avoid twisting and bending so the torso shape isn't crushed or distorted too much; eventually they won't be able to move anyway.
comment
Add Comment
Add Comment
