3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Packing Tape Dressform
Step 4Tips for Taping Shapes
I already mentioned about using short thin strips to cover rounded areas like the chest, some other areas you should watch out for are the dips by the collarbone, area between the shoulder blades in the back, around the waist (lovehandles?), and underarms to shoulders...
To keep the integrity of a depression area, push the tape into the valley part first, then smooth outward letting the edges of the strips fall where they may.
I used a V- shape pattern to tape the back between the shoulder blades.
If you notice an area tenting too much, don't be afriad to cut it off (just the tape, not the shirt) and re-tape that area with smaller pieces.
Having the tape overlap in all different directions will create a stronger contoured shell.
You might also want to create "spines" (such as a cross shape over the front and back) to support the entire structure more.
To create extensions (say, if you are using a crew neck shirt instead of a turtleneck) use a vertical strip, tape to the inside of the shirt with the sticky side out. Then fold it over onto itself so that the ends are sandwiching the shirt but the tape sticks out to the length you need the form to cover. Space these extension prongs a few inches apart, and then tape them together using the same method (folding the tape over onto itself, but sandwiching the tape next to it).
Use a hair dryer to dry any pieces that are still wet.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:stijky
