Custom Fit Earbuds
 by mhdguy
Hello all This is a project I have wanted to do for almost three years but hit a bit of a stumbling block I could never find a product that let me mold it to the shape of my ear and would harden without much shrinkage.
Finally thanks to mikey77 and his OoGoo  I have a material that not only has all the properties i was looking for but removes most of the building complexities as well
Step 1: You need
Items you need
Clear 100% silicone
Cornstarch
Earbuds with removable ear cushions
cheap pen
a small drill bit
paper cup
gorilla tape
optional dremal/drill
dustdevil02 says: Jan 21, 2012. 3:34 AM
Is it safe to smell the vapour of the silicon for like an hour because I took an whole hour experimenting this, and I thought the silicon releases some kind of chemical that will harm our body even after it cured, is it true?
mhdguy (author) in reply to dustdevil02Jan 23, 2012. 6:05 AM
from my understanding of it the only "vapor" released would be vinegar. (i'll leave it to one of this sites many awesome chemists to validate that 100%).
though i haven't found any negative side effects as of yet if you are worried about long term exposure causing problems you could always try experimenting with food grade silicone
trashcracker says: Sep 12, 2011. 1:57 PM
This was a great and simple project. I ride a motorcycle and have always had trouble keeping my earphones in my ears because they don't fit tight enough or stick out just a little too far so my helmet pulls them out when I put it on. When I put my earbuds in the oogoo I made sure I pushed them in as far as I could and my first ride with them was great.
mhdguy (author) in reply to trashcrackerSep 12, 2011. 2:02 PM
I've just started using them the same way ... only problem I've found is over time they shrink enough that on a bike at high speed the wind can get underneath and blow them out.
trashcracker in reply to mhdguySep 12, 2011. 5:48 PM
I guess the good thing is that they are crazy cheap to make.
mhdguy (author) in reply to trashcrackerSep 12, 2011. 7:29 PM
ya true
although i tend to destroy the headphone wires before the pads need to be replaced
mikesnyd says: Aug 11, 2011. 11:02 PM
take a q-tip with some vasiline on it and wipe some on the inside of your ear. not a whole bunch but just enough to make a good oil barrier
dopman says: Apr 20, 2011. 3:27 AM
Great Instructable!
I made some earplugs this way and I'm going to make earbuds for my drumming soon too! :D
Theese are great for music doesent just let the base go through you will hear the high-tones too! :)
mrmoonshineman says: Jan 24, 2011. 11:17 AM
I wonder if you could put a sheet of saran wrap between your ear and the oogoo? acid burns don't sound like my cup of tea.
SLOB7 in reply to mrmoonshinemanApr 2, 2011. 4:34 PM
for another project I made (toe spacer for a reoccurring corn) I put some OoGoo into the finger cut off of a latex or nitrite glove then tied it off. I'm sure it would work for this also. its a lot easier getting the goo into the glove if you dust it with corn starch then slide it into the glove. once its tied you can knead it to mix the extra starch into the blob.
mhdguy (author) in reply to mrmoonshinemanJan 24, 2011. 11:23 AM
recently I've been dipping the piece I'm using into cornstarch to act as a barrier directly before i stick it in haven't had any problems since i started doing it that way makes them come out a bit easier too
patthesoundguy says: Oct 30, 2010. 4:03 PM
there are kits online to do this very thing. But they cost $100 so this is awesome, Im going to give it a go thanks for posting it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
