Custom Gear Motor Mount
Introduction: Custom Gear Motor Mount
Did you ever have a piece that you wanted to mount to something else, but couldn't figure out an easy way to make it work? This instructable shows a fast way to put things together.
Step 1:
I started with a gear motor
This is very powerful and cost effective, but it has lots of round and complicated shapes involved.
Step 2:
I just squished the motor into Sculpey clay to make a model of the complex configuration on the bottom of the motor.
Although I used a scanner, software and 3d printer to create my mount, you could make a couple of mounting holes and bake the clay to achieve about the same result.
Step 3:
Scan the clay mold.
At, I combined the scanned clay base with a designed flat piece (plate with four holes). Then, using the Tinkercad "hole" tool, I made a couple of holes in the scanned piece where I could secure tie wraps.
3D files are here:
Step 4:
In just a few minutes design time (and a few hours print time), I created a secure mount and can continue working on my project.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    For a one off I'd have wrapped the motor in a polyethylene freezer bag replaced the sculpy clay with car body filler once set drilled a couple of holes for the cable ties job done.
    Interesting technique. Thanks for sharing this!
