Custom LED Touch Light Fixture
Introduction: Custom LED Touch Light Fixture
LED Contest with Elemental LED
Finalist in the
My wife and I really didn't care for the light fixtures that came in out fifth wheel camper, so we decided to replace them with a pair of cheap, matching fixtures we found on clearance. Since the camper lights run on 12V DC, I knew I would have to rip out the 120V AC sockets and replace them with 12V DC ones as well as as some sort of switch. Of course, I ended up over-complicate things, and after one thing lead to another, I ended up designing and building a set of LED fixtures with multiple brightness modes that operated by a simple touch of the fixture.
LEDs are much more efficient than the bulbs in use and will probably never have to be replaced. The decision to make the fixture touch sensitive came from my difficulty in finding a suitable push on-off button in white that can handle larger amounts of current.
Although my design is based on a 12V DC power source, a similar project could be made by using a regulation circuit to convert the AC power in your home to a suitable DC level. Remember, any time you are working with electricity it is VERY important to turn off the power source before you try to connect anything. NEVER work with live voltage lines!
I posted this project on my website a while ago, but I thought it deserved an Instructables makeover! It project involves a bit of complex circuitry design and programming but has been a lot of fun, and if you are ready and willing than so am I! Let's get to it...
Step 1: Gather Your Materials
Normally, I would say the first step is to figure out what you are wanting to do, but I kind of already did that for you! So we'll just skip straight to the necessary components and tools. I believe I have listed everything that I used, but in case I missed something, all of the parts should be labeled in the upcoming schematic, and what tools you may need or want to use will really depend on your style of doing things and the fixture you choose to use!
Drill with various sized bits and and drivers
Needle Nose Pliers
Wire Cutters
Wire Strippers
Soldering Iron and Electrical Solder
Hot Glue Gun
Computer - To view Instructable, look at designs, and download program
AVR Programmer - I use the Pocket Programmer from Sparkfun
Multimeter - Always useful when building circuits!
Computer Programs
Eagle PCB Designer - for schematic file viewing and editing (Optional)
WinAVR - To install the source code (AVR Studio should also work)
Light Fixture to Convert - Needs to be conductive at the core, but can have a non-conductive coating.
Screws to Mount Fixture - Should come with the fixture
Small bolt and a few nuts - to connect our touch sensor to the fixture
Piece of sturdy cardboard - roughly the size of the fixture
Aluminum Foil
Electrical Components - All available at Digikey
Small Perf Board to solder components - the size depends on your ability to solder and what fits in your fixture
Small Guage Wire for circuit connections - I used gauges 30 and 22
Various Wire Caps for safe connections
Large Guage wire for power and LED connections - I used 10 guage wire
Roll of warm white surface mount LEDs - I found mine on Amazon
1 x AVR ATtinyx5 microcontroller - the "x5" means any uC in that line will work: 15, 25, 45, or 85 [ Datasheet ]
1 x Atmel AT42QT1010 Single Channel Touch Sensor [ Datasheet ]
1 x 8 Pin DIP socket for uC chip
1 x 3.3V regulator (could work on 5V, but I wanted less power consumption) - I used the MCP1702 [ Datasheet ]
1 x Logic Level N Channel Power MOSFET, Must fully turn on at regulated voltage level! - I used the STD50NH02 [ Datasheet ]
1 x NPN Transistor - I used the common 2N3904 [ Datasheet ]
1 x 3 Position Screw Terminal for Power and LED connections
4 x 4001 Rectifier Diode
1 x 100uF Electrolytic Capacitor
1 x 10uF Electrolytic Capacitor
2 x 1uF Electrolytic or Ceramic Capacitor
1 x 0.1uF Ceramic Capacitor
1 x 0.01uF Ceramic Capacitor (Optional)
1 x 47nF Ceramic or Polyester Film Capacitor
7 x 10k Ohm Resistor
1 x 0.33 Ohm Resistor - Must be rated at least 1.5 Watts!!!
Step 2: Circuit Design Overview
The circuit can be divided into four sections: power supply, touch sensor, microcontroller, and LED driver. The touch sensor is connected to the frame and alerts the microcontroller whenever it is activated. The microcontroller then sends a pulse to the LED driver to power the lights. The pulse width determines the LED brightness, and has three modes: low, medium, and high. The power supply regulates the voltage for the electronics, but the LEDs receive power directly from the 12V battery.
The circuit was created in Eagle PCB designer, and I have attached the latest version of the schematic.
I will also cover each of the four circuit sections in more detail in the following steps. If you are not interested in how they work, you can skip to Step 7 to see the complete soldered circuit!
Step 3: Schematic Overview 1 - Power Supply
This circuit is designed to run on 12V DC, but it could really be sourced by anything (including AC mains) as long as proper regulation is used. I chose a logic voltage of 3.3V instead of the more widely used level of 5V because the components will consume less power. The MCP1702 regulator comes in a 3.3V package, but can only accept inputs up to 13.2V. However, a 12V battery  charger will actually reach a level of around 14.4V DC, and for this reason, I placed 4 series diodes before the regulator to ensure the input voltage does not exceed this level. The first capacitor, C1, is to help supply the LEDs with immediate power when they are turned on. The surrounding capacitors are needed for proper regulator output and voltage stabilization. If this circuit were to be used in a typical house using an AC voltage, a transformer and rectifier circuit would need to be used to create a suitable DC level for the LEDs as well as an acceptable input level for the shown 3.3V regulator.
Step 4: Schematic Overview 2 - Touch Sensor
This is really the central component of the entire circuit. I used a single channel touch sensor chip from Atmel - the AT42Qt1010. The only bad thing about this chip is that it didn't come in a through hole part, so I had the joy of soldering a tiny surface mount component to the perf board... but more on that later. The sensor really works through capacitance, and it is important to get a proper value for C7. Without being connected to the fixture, the LEDs would randomly turn on and off just by walking by the circuit, but this high of a capacitance was necessary for the large fixture to be sensitive enough to work. A different sized light fixture may require a different sized capacitor. The two shown resistors are only there so the sensor is not directly connected to the fixture or two the microcontroller.
Step 5: Schematic Overview 3 - Microcontroller
The Atmel AVR ATtiny25 is the heart of this circuit, although any similar uC could be used. It has two jobs: 1) Wait for input from the touch sensor and 2) Send an appropriate pulse to the LED driver. The only other thing this uC should do is conserve power, so it waits in a sleep mode which can only be interrupted by a pulse from the touch sensor. The bypass capacitors C5 and C6 are not entirely necessary, but at least one of them should be used. The resistors R6, R7, and R8 are used to safely connect the unused pins to ground. Floating pins are never a good idea, and directly connecting a pin to ground or a voltage can be dangerous if a pin goes into the opposite state for whatever reason.
The LED driver is connected to a dedicated hardware timer output, so it's operation is independent of the main processor, but I'll talk more about that in the Step 8 - Source Code.
Step 6: Schematic Overview 4 - LED Driver
The LED driver is a very simple constant current source with a pulse width modulated (PWM) input from the uC to control the LED brightness. The operation is pretty straightforward as well. When a voltage is present on the gate of Q2, the MOSFET, it turns on, allowing current to pass through like a relay switch. The transistor used will determine the voltage level necessary, but mine fully turns on with the supplied 3.3V from the uC. Current flows through the LEDs and into the resistor R3. This is where it gets a bit interesting. Q1 will also turn on, and will do whatever it can to maintain a constant base to emitter voltage level of 0.6V. Other transistors may settle at a different voltage level. This constant voltage across R3 forces a constant current through the resistors. The current is essentially V-Q1,B-E / R3, or in this case 0.6V / 0.33ohms which equals 1.81 amps. Of course, this current is shared through many strings of LEDs, 24 to be exact, meaning each LED will have a full on current of around 76mA. The data sheet for the 3528 SMD LED states that a constant forward current of 50mA or a pulse current of 100mA is acceptable, so we should be in the clear as long as the LEDs are pulsed.
The brightness control comes from the pulsing. If a pulse width of 50% is used, than the LEDs will only be on 50% of the time and will appear at about 50% of the total brightness. This is because the human eye has a slower refresh rate than the pulse frequency, and the LED retains some afterglow in its off state. A frequency of 122 Hz was used for the LED pulse.
Step 7: Building the Circuit
I always try to use through hole parts when working with a perf board, but they aren't always available. In this case, the touch sensor only came in small SOT23-6 package. I was able to glue the part to the board and solder small wired directly to the pin leads. I then covered the chip in hot glue to prevent the wires from getting yanked off.
The rest of the build was pretty straight forward as long as you know how to solder. The most important thing to remember is that the wires going to and from the LEDs need to be bigger gauge because of the larger current flow. Another important aspect is heat regulation. The MOSFET transistor will get hot sinking this current, even though it is rate for a much larger one. This component cannot be up against other things because it will need plenty of airflow and potentially a heat sink for proper operation. I learned the hard way and had to replace it twice before decided to house that particular component outside of the fixture, but more on that in Step 10 - Completing the Fixture.
Step 8:
Don't worry if you don't have any programming skills, I've done it for you! The attached file is the most up to date source code I have for the project. I have also included the various header files and makefile needed for the project to compile.
I used WinAVR to compile and the USB Pocket Programmer from Sparkfun to download the code into the AVR chip, but you could use AVR Studio and whatever programmer you are used to; just be sure to alter the makefile accordingly. The AVR fuse bits are the default values.
Program Operation
Basically, the uC waits in sleep mode until it is woken up by a hardware interrupt from the touch sensor. It then turns the LEDs on in a low state. When the sensor is touched again, the mode is changed from low to medium, and again to high after another touch. One final touch of the fixture will turn the lights off and put the uC back to sleep, waiting to be woken up by the touch sensor. This cycle repeats itself indefinitely.
Two header files are in use. The first is my custom AVR.h file which contains many useful macros as well as calling other required headers. The second is the sleep.h file that is included with WinAVR.
The program starts by initializing the AVR chip: turning off unused features, setting the I/O ports, reducing the system clock frequency (for more power savings), setting up Timer 0 for a 122 Hz pulse, enabling the pin change interrupt for the touch sensor, and enabling the power down sleep mode.
The program then enters a forever loop which only does one thing: check to see if sleep is enabled. If sleep is enabled, the uC is put to sleep to wait on the touch sensor's hardware interrupt.
Only one interrupt handler is used: the pin change interrupt for the touch sensor. This routine checks the state of the LEDs and decides to turn them on, increase the brightness (pulse width), or turn them off accordingly anytime the fixture is touched. It also holds the program in a loop until the fixture is no longer being touched.
The LED pulse is handled entirely by hardware features of the uC. The only thing that has to be done in the code is to enable or disable the Timer 0 output connected to the LED driver.
Step 9: Preparing the LEDs
I picked up this roll of LEDs from Amazon. The main thing to consider when purchasing these LEDs is the color. White LEDs can be a point of confusion for some. There are actually cool white LEDs and warm white LEDs. The cools have more of a blue shade and will alter the way things normally appear under light bulbs. This can lead to disappointment if you are not anticipating this change. Warm white LEDs more closely resemble the yellowish light emitted from a standard light bulb or the sun.
The roll of LED strip lights I got was great, but came ready to be used meaning each string of LEDs already had a series resistor. The roll is basically a bunch of 3 LED strings in parallel, so it can be broken up every 3 LEDs. The series resistor in each string needs to be shorted or the current source LED driver won't work correctly. Wait, am I suggesting you alter (or ruin, as my wife would say) a perfectly good roll of LEDs? Why yes, yes I am.
I used 24 strings to provide enough brightness, but your necessary amount of LED strings may increase or decrease. If so, be sure to adjust the value of R3 in Step 6 accordingly to provide the correct amount of current through each string.
I recycled the leads of components I cut off when building the circuit and used small pieces of solid wire when I ran out of cut leads. The traces on the LED strip can be soldered to directly. When that is done, each LED string needs to have a pair of lead wires so they can all be connected in parallel.
Step 10: Completing the Fixture
Now comes the fun part - putting it all together! To start, we need to take out all of the socket pieces that come in the fixture. The circuit can then be attached. I was able to bolt mine through the hole left by the original socket, but you may need to drill a hole for this purpose. The lead connecting to the touch sensor was wrapped around a small washer on the bolt, connecting the sensor to the conductive core of light fixture. Although the outer coating is not conductive, the sensor is sensitive enough to work through it because it senses the change in capacitance with respect to ground as a finger approaches. In fact, it will work without a complete physical touch, a finger (or nose, if you're in the mood) just needs to come very close to the fixture.
At this point, the fixture can be mounted in the ceiling. I am assuming there is already a hole with the power leads available. The power can then be connected to the circuit with wire caps.
The next step is to create a housing for the LEDs. I used a piece of sturdy cardboard and bent to wings to force some of the light down at an angle, and lower the LEDs from the circuit. The cardboard was wrapped in alluminum foil to aid in the LED head dissipation and to make it look nicer. Once the wires have all been connected and capped, the LED housing can be attached to the fixture using a few strips of Velcro. This allows it to be easily removed for access to the circuit or to remove the fixture.
Step 11: Heat Considerations
As noted in Step 7, the heat dissipation of the MOSFET is very important. I burned up two of these parts before I really solved the problem. Because the LEDs are enclosed in the glass fixture covering, the fixture interior air quickly heats up when the LEDs are on. Since the MOSFET is also hot from sinking a large current, it needs proper airflow to cool off, but it cannot if it is surrounded by other components.
The first time the MOSFET quit, the LEDs flashed a few times, and then remained in a dim state. The fixture was unresponsive, so I took it apart to work on it. I ended up running wire leads to the circuit and attaching a new MOSFET to these leads hoping that the part would get enough air flow raised off of the circuit. But after a few days of running, it too gave up.
This time, I decided to run the MOSFET leads through a small hole I drilled outside of the fixture. The part would still be concealed by the fixture outer rim, but it would be outside of the hot air filled interior and stood a chance of keeping cool. I also affixed it to a large heat sink. This solution has been very effective. The entire fixture has worked flawlessly with this heat dissipation in mind. I also covered the surrounding fixture area with electric tape to prevent the heat sink from touching the fixture and effecting the sensor sensitivity.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    Hi Kurt!
    Why do you parallel LED strings? It increases the current and decreases the circuit performance.
    To start, your statement is mostly incorrect, but I will explain anyway.
    Because it would take a fairly complex circuit to boost the source voltage to a high enough level for enough series LED strings to produce necessary light. Of course, a single (or few in series) high power LED could be used, but I just used what I had on hand. In addition, more or less current draw is trivial - the power usage would be the same. Boosting to 120V DC at 1A is the same power used by 12V DC at 10A.
    On that note, higher power LEDs are extremely inefficient when compared to these lower powered ones. The ambient light produced does not increase linearly as the power used (and current drawn) increases. A 10W LED does not produce 10 times as much light as a 1W LED, but it does draw 10 times the power. The only reason they are used at all is limited space and the cost of larger printed circuit boards and multiple heat sinks.
    By the way, these rolls of lights come as groups of [3 series LEDs and resistor] in parallel with other groups of [3 series LEDs and resistor]. That is how they work. In fact, that is how pretty much how all LED lighting in existence works.
    Sure, I changed that a bit to make some groups of [3 series LEDs] in parallel share a single resistor in order to increase the current through them and so they would work appropriately with a PWM driver, but I am still not driving them anywhere near their maximum current raiting, and as such, no effects of parallel loading will be seen. These lights have been operating properly in my RV for years.
    I see, thank you.
    I use halvanically non-isolated hi-freq custom made AC-line LED driver circuits based upon Power Integrations ICs like LNK306. Carefully mica insulated heatsinks being applied in order to prevent electric shock hazards.
    What I wanted to say... As my "PI Expert Suite" goes: the more output voltage (i.e. the less the difference between input and output voltages) - the higher efficiency we get.
    For example: 30 LED x 3,3V = 100VDC output (for 220VAC/300VDC input) - we have certain calculated efficiency for this device. Then let's load next design: 10 LED x 3,3V = 35VDC output for the same 220VAC/300VDC input. Press "CALCULATE" button and see that new efficiency is less than the previous one for about a 20%. For all the same the rest of parameters!
    Another one point. When I bougt on eBay 10W LED set (single case clustered LED emitter + 220VAC hi-freq LED driver), I paid attention on the driver's size and weight. It was more than two times larger and heavier than ordinary 9W 220VAC hi-frec LED drivers I bought a couple of weeks before.
    And I understood that 9W (or "10W" as they marked it) single-cased cluster contains 3 LED parallel strings, consist of 3 LED each in series. I.e. 300 mA each string * 3 = 1 A consumption of the whole claster. Concerning voltage: each string contains 3 emitters in series that gives us 3 * 3,3V = 10VDC.
    Resume: we have AC-line LED driver of 10VDC*1A = 10W to run our 10W ready made LED cluster. Really BIG, EXPENSIVE AND CLUMSY driver in comparison with plenty of ordinary 9W LED AC-line drivers (which can run 9 * 1W LED in series = 9 * 3,3 = 35 VDC output) which are pretty smaller, lighter and of the very same output parameters...
    I see that YOUR circuit is ultimately different (linear MOSFET-based current source), but I just share my own applied experiense in the field. ))
    I think I understand what you are saying... (I assume English is not your first language? It's still a lot better English than my sometimes correct Spanish...).
    Also, AC and DC are two different entities entirely when it comes to efficiency.
    Right you are, my native language is Russian. AC from the wall outlet becomes DC after rectification, i.e. 220AC becomes 300VDC across filter capacitor.
    Well, my Ruslish is definitely poor as I suspect, but I did my best! ))
    I see you mentioning running on Ac mains, but how do you propose connecting this to 220-240V AC? planning to build for this to a new project! :)
    Yes, this can be done from AC mains (120 or 240V). What you will need is an appropriate sized step down transformer to drop the high AC voltage to a more suitable level. This lower AC voltage will then go through a diode bridge rectifier and finally a smoothing capacitor to transform it into a stable DC voltage. Take a loot at this project I did a while back that discusses this process in detail. Also note, my project worked off 120V AC, so a different transformer would be needed for the international 220-240V standard.
    Great Man it's simple one i saw was designed from arduino it was also good but since i do not have arduino i prefer this way! Thanks for sharing.
    Yeah, this is better than most Arduino versions - primarily because it doesn't involve arduino. The current driver can be replaced by a simple MOSFET switch and it will still work perfectly fine.
