Custom Music Maker
694
13
Posted
Introduction: Custom Music Maker
Hello!! This is my first time posting here. I would like to share to all of you about a project I made using arduino,the custom music maker.The project actually takes laptop keyboard as input and buzzer sound as output.This means that when we press some keys to our laptop keyboard, we will get some sound coming out from our buzzer, something like a piano!!!!! .Here are list of Items that will be used in this project:
1)Arduino Unox1
2)Buzzer x1
3)BreadBoard x1
4)Jumper Wires
5) resistor(optional, I did not use resistor in this project)
Softwares:
1)Processing IDE
2)Arduino IDE
Step 1: Assemble and Program the Circuit the Circuit
The Circuit were assembled as sketch(made by fritzing) above. Pretty easy right? Now Let's program the circuit for our keyboard input, we use Processing IDE and Arduino IDE for this.
PROCESSING IDE:
import processing.serial.*;// so that we can connect to arduino
Serial port;
void setup()
size(200,200);
port = new Serial(this, "COM21", 9600);//declaring our port that arduino uses
void draw()
void keyPressed()//this part shows the program for the keyboard key to be pressed
if(key == 'q'){ //example when key "q" is pressed
port.write('q'); //the processing IDE sends data "q" to arduino
if(key == 'w'){
port.write('w'); }
if(key == 'e'){
port.write('e'); }
if(key == 'r'){
port.write('r'); }
---------------------------the end------------------------------------------------------------------------
actually you can just add more keys under the void keyPressed function. I just show 4 example.
You can add more by this format:
if(key == alphabet){
port.write('alphabet');}
ARDUINO IDE:
int spk = 9;//buzzer pin
int val;//value = 0
void setup()
Serial.begin(9600); //set serial communication at 9600 bps
pinMode(spk,OUTPUT); }//set buzzer as output
void loop()
if (Serial.available()) { // if serial communication available
val = Serial.read(); //value is = to the what the processing read
if(val == 'q'){ //if value is equals to 'q'(means when we press 'q' the processing IDE sends data 'q' to arduino)
tone(spk, 1915,200); }//a tone will be produced with frequency 1915, period 200ms at pin 9(spk)
if(val == 'w'){
tone(spk, 1700,200); }
if(val == 'e'){
tone(spk, 1519,200); }
if(val == 'r'){
tone(spk, 1432,200); }
you can add more tone values for more alphabets but you also must add the alphabet under the keypressed function in the Processing IDE. in Arduino the format for adding more tones for more alphabets is:
if(val == 'alphabet'){
tone(buzzer_pin,frequency,period);}
BUT REMEMBER ADD IN PROCESSING IDE FIRST!!!!!
Step 2: Enjoy Your Music Maker!!!!!
Now your music maker is finished let's test it out. first run the program in arduino first and then processing..This is the sample that i made..Good luck.. Also I would like to ask for apology if i made mistake because i am still new in arduino and also instructables... thank you very much
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    Very nice gadget, and the sounds it makes are very fun! You arduino looks very nice, especially for a beginner! Welcome to instructables, hope we get to see more from you!
