3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom Nameplates: LED Star Power!
This is one of my favourite nameplates, which I made for the daughter of some close friends.  Will she still like it once she's in school?  I hope so!  The letters of the name are glued onto a back panel of five connected stars, illuminated with white LEDs.  The back panel is made of Baltic birch plywood, laminated board, and Lexan sheet.  The letters are made of maple.
This design is easily modified for almost any name:  simply cut out different letters and arrange them on the same back panel.  Of course, you may also change the LED colour, and stain/paint the wood a different colour to match the room.
Step 1Materials and Tools
Materials and Tools
You should be able to find most of the materials at any hardware store.
- One 12x24" piece of 3/4" baltic birch plywood
- One 12x24" piece of 1/8" white-laminated fiber board (or unlaminated board, painted white)
- One 12x12" piece of 1/8" transparent lexan or acrylic sheet
- One 4"x1"x24" piece of quality maple (or almost any hardwood)
- Clear finish (I use Minwax Polycrylic)
- Oil or Water-based stain (I used "Cabernet" - a deep red colour)
- Two-part epoxy
- Carpenter's glue
- Five white LEDs  (I buy mine on eBay)
- Five 510 ohm resistors (minimum) - for use with a 12V adapter
- Some bits of wire
- A 12VDC "wall-wart" adapter  (minimum 200mA)
- A matching DC jack
I made this nameplate by hand on a scroll saw and band saw, but you might be able to do some of the parts with a CNC machine.  I'd only recommend using a laser cutter for the plastic parts, since the wood is too thick to cut with a laser and I dislike the burnt edges that result anyway.
- a variable speed scroll saw (I use a Dewalt 788)
- a bandsaw (optional)
- a drill press
- an overhead router (I used a dremel with a router bit, mounted in a drill press stand)
- a vertical sander
- an X-acto knife
- a small chisel
- skip-tooth and crown tooth blades for the scroll saw
- soldering iron
- sandpaper
- paintbrush
16 comments
Aug 26, 2010. 8:00 AMNinzerbean says:
All I want for Christmas now is a scroll saw, amazing job!
Aug 26, 2010. 8:47 AMNinzerbean says:
Could you recommend a particular brand? Are they all the same size? Can you use a metal cutting blade?
Sep 16, 2010. 4:58 PMSpaceBiscuit says:
I would also recommend the Dewalt DW788 - I just purchased one for $450, it came with the stand and light. Also I use Flying Dutchman Ultra Reverse Blades. To remove the paper pattern from the wood, I use a heat gun.
Aug 26, 2010. 9:11 AMNinzerbean says:
Wonderful information - thank you ever so much, I think this is just what I need, and have needed, but I didn't know what it could do. I use my jewelers saws for so much and it is slow going on a big piece of metal - like a street sign.
Aug 26, 2010. 10:28 AMNinzerbean says:
I have a 15 inch bandsaw, pretty big, I love it but it can't do what this scroll saw seems to be able to do. I can use the band saw for the big stuff for sure. I have the Dewalt in my shopping cart on Amazon, I'm going to sleep on it before I hit the buynow button. Thank you so much for your help.
Aug 29, 2010. 9:00 PMluvit says:
please make one with shaun cassidy;s name. i'll buy it.
Aug 26, 2010. 10:37 AMscoochmaroo says:
This is the awesomesauce. Next gift exchange, my name is spelled s-c-o-o-c-h-m-a-r-o-o :D
Aug 26, 2010. 8:13 AMtechnoplastique says:
This turned out fantastic - Teaghan is a lucky kid!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
346
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
