3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom PCB Prototyping using a Laser Cutter
Step 4Clean up the board
clean up the board
Now as you can see, the result of the lasering is beautiful, however we are not ready for etching just yet.  There is a very thin layer of paint residue left on the copper that will block the etchant solution from working properly, and will slow that process down a lot.  Here's what to do : Soak one end of a q-tip in  rubbing alcohol (ethyl or isopropyl) and spread it on the exposed copper. Try to keep it off of the black paint, because we want that to stay.  Use the other end of the q-tip to rub away, essentially polishing off the copper, making it shiny and ready for etching.  You can see in the second image, the board on the far right has been cleaned, and is shiny and ready to go.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:jmsaavedra(http://jos.ph)
