3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom PCB Prototyping using a Laser Cutter
Step 5Cut boards and etch
cut boards and etch
It is really your choice to cut the boards first or etch the entire board and then cut it afterwards.  I feel that you need less solution and a require a smaller container if you cut the boards first, and then etch afterwards. With Radioshack's Etchant Solution (Ferric Chloride), you only need to use a little more than enough to cover the boards entirely. Once the boards are submerged you need to "agitate" them for about 20 - 30 minutes.  "Agitate" really just means move around -- I simply lifted and dropped one end of the container every 10 - 20 seconds.  Nothing rough, just a slow wash.  After about 5 - 7 minutes you will begin seeing the orange copper disappear and the yellow color of the fiberglass underneath start to come through.  By the 30 minute mark there should be no more orange copper, only black lines on yellow.  You are done.  As the bottle says, flush the excess solution, and rinse the boards with water in a sink.  The solution will stain, so be careful.  It will also smell of a bizarre and unpleasant musk.  This is normal if you use ferric chloride.
1 comment
Apr 2, 2010. 4:42 PMmattve says:
did you used the laser to cut the boards as well, or a different method?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:jmsaavedra(http://jos.ph)
