3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom Paint Your Old Snowboard!!! (for your Valentine perhaps)
My girlfriend really wanted me to teach her to snowboard this season, so I decided that if she wanted to try, she might as well have some good looking gear. Since a brand new board/boots/bindings would be a bit out of my league, I figured one of my old boards would fit her perfectly, and I could make it look new again...so this is how I did it. It's not perfect, but I must say I'm happy with how it turned out. Most importantly, my girlfriend LOVED it! She got it a bit early for Valentines day, but hey, ya gotta go when the snow falls.
I couldn't find any solid, picture-filled write-ups on the topic, so I figured I'd record my trials. I'm sure there's some experienced and opinionated painters out there. Hit up the comments. I'd love to here any pointers you may have learned along the way.
Step 1Tools and Materials
Tools and Materials
I used cheap and readily available materials for this project. From what I heard, the harsh winter elements would be the eventual ruin of the even best paint and painting. If the materials I chose are used correctly, I'm sure they can work great....I think I came pretty close.
Wants and Needs:
Old Snowboard (or an ugly new one)
A Design Idea!
Time....enough for complete drying
Well Ventilated Area
Newspaper
Lots of Masking Tape
Goggles and Mask -if you're painting inside you should use a respirator. I should have had one for this project.
Epoxy
Scotchbrite Pad
Sand paper in various grits
Alcohol
Dupli-Color Prep Wipe
Dupli-Color Black Primer
Dupli-Color Black Paint
Contact Paper (If you're stenciling)
Compass and Compass Cutter
CD's - guide for cutting circles
Rustoleum Florescent Pink
Rustoleum Sugarplum
Razor Blades
Sharpies
73 comments
1-40 of 73next »
Feb 12, 2012. 2:01 PMkairedfern says:
You say for the edges of the board you used a cd- like you pressed the CD on the bent parts to be able to make the design? Cause the tips that curve are troubling me
Feb 13, 2012. 4:08 PMkairedfern says:
Whelp then I'm doing it.
I'm probably driving you insane with all these comments
Mar 23, 2012. 2:58 PMkairedfern says:
WELL!! I put the white contact paper on, then sprayed several layers of clear coat and white on that. Annoying, the paint did that crackly thing and I sanded it down. When it gets warm and non-windy again, I'm gonna do just one layer of white then start the circle layer
Feb 12, 2012. 1:57 PMkairedfern says:
So your compass worked when drawing circles for where to board bends upward?
Feb 7, 2012. 10:17 AMkairedfern says:
Can we not sand?
Feb 10, 2012. 7:28 PMkairedfern says:
Thanks :) I've found a very rich blue and a purple, doing it on a white background to match my bindings.
Feb 10, 2012. 6:46 PMkairedfern says:
What was the diameter of the circles you used?
Feb 7, 2012. 10:19 AMkairedfern says:
I was just going to use Krylon spray paint, what did you use for a primer?
Feb 2, 2012. 5:10 PMkairedfern says:
So would you recommend putting a line down the middle and the center of the board, then starting with a line of circles there; then from that line, branch out? Also, how hard did you press?
I should practice beforehand xD
Feb 5, 2012. 1:03 PMkairedfern says:
I'm planning on doing a layer of contact paper, spray paint on that, then doing your clear paper stencil cut out thing, then coloring like you and a clear coat.
Jan 24, 2012. 9:11 AMkairedfern says:
So I want to paint mine, and I plan on cleaning it then just putting contact paper on then doing all the art on top of that. I don't wanna ruin my only board, cause I'm tight for money. After the art is done, should I do the spray-on clear coat or another layer of clear contact paper or both?
Feb 6, 2007. 4:05 AMneckfire says:
I've actually done this before (not as fancy a paintjob of couse- I actually used brush on arcylics) But to get the nice shiney finish I actually used a varnish of some sort. I painted it on real thick and let it even it self out and dry. It never really chipped. Heald up almost as well as the original varnish. Only thing after a year of use it got a bunch of cracks in the varnish from the board flexing. Looked pretty cool honestly. Great tutorial! :)
Jan 24, 2012. 1:01 PMkairedfern says:
Curious, what kind of varnish?
May 26, 2011. 11:57 AMElectroinnovation says:
Well im done!! I have yet to ride it...but I put a really good layer of hot wax on the bottom and used about 2 cans of that clear enamel protectant spray. I hope it holds up becasue I think im in love with itt!! The first pic is the bottom and the second is the top.
Dec 28, 2011. 8:52 AMElectroinnovation says:
Thanks! I just tried it out on the snow yesterday and it actually went really fast even though I painted the bottom! I guess the poly spray and hot wax helped it out a lot
May 3, 2011. 2:27 PMPyromaniacDaniel says:
I am considering painting my board and have been researching the viability of doing so. I was wondering how well this held up for you?
Nov 25, 2011. 5:52 PMsistergldnhair says:
this is realy cool i just got a snow board myself
Apr 15, 2011. 11:59 AMmcovey says:
Thanks for the info I am planning on painting my board soon and after talking to my uncle who is an autobody man I have decided to go with a type of paint called POR-15 I have used it on cars before but hadnt though to use it for
this but the stuff is strong. you can hit it with a hammer and it wont chip or scratch both the clears and the colors they have. the paint is called POR-15
http://www.advanced-rust-protection.com/por-15-hardnose.htm
I was planning on using the hardnose color paint then vinyl stickers
for the design I want and then a clear coat of the POR15 over that.
I was only planning on the clear because I wanted to seal the vinyl in
real good.
I will hopefully be doing this soon on my board and can give you
updates to how well it works and some pics. as for on the slopes that
will be awhile for those results.
Apr 11, 2011. 7:58 PMnealwm says:
I custom painted my partners skis that he purchased used (the bottoms were in good condition but the top sides had their share of scratches and dings...but no delamed rails!) and figured it out on the second attempt. After roughing up the surface to be painted with medium grit SP I put down 3 light coats of an automotive surface primer (grey) made specifically for fiberglass applications. After each coat was completely dry (!) went over with steel wool using a finer grit each coat. I was going to do a color coat but liked the grey mat look. I then threw paint of various colors onto the grey ala Jackson Pollock and when fully dry gave the whole ski top surface two coats of Spar Varnish. He has used them three times without any chipping or color loss. One important note: Tape off the metal edges on the ski/snowboard well as this needs to be free of anything specially wax and paints.
Mar 18, 2011. 3:17 PMElectroinnovation says:
I started to spraypaint my old board and so far I'm almost done with one side. I just have a quick question, how many layers of the clear coat would you recommend?
Mar 19, 2011. 5:04 PMElectroinnovation says:
Okay thanks...but I did paint the bottom :P haha but I have some wax and ill definantly wax it when im done so it should hold up decently. Oh well i dont even care about the board anyway thats why I'm doing it. And thanks for the info I'll post pictures soon.
Mar 21, 2011. 3:32 PMElectroinnovation says:
True haha. Well snowboarding season just ended for me where I live so I'll have to let you know how it works next year...if i remember...
Mar 10, 2011. 8:19 PMTofu-Sama says:
Two suggestions to improve fixing cracks. Automotive (bumper) epoxy is black, and much more flexible than regular epoxy, so it's generally a better choice for a board. Two, you can wrap anything that will touch the epoxy in wax paper, and the epoxy won't stick to it. I've used those two methods to create perfectly smooth repairs on my board's topsheet.
Jan 23, 2011. 10:59 AMkristylr says:
if you roll out the contact paper on a flat surface and draw your design on it first, then apply to the board it will be easier than drawing the design on a curved surface. And if you sand off all the old paint job and get it down to just the board itself then you won't add any weight to the board with the new paint.
Jan 23, 2011. 8:31 AMbabyspider says:
did any of you that tried this notice any significant amount of weight added with all the coats of paint and sealer ?
i have a board that could use a new look but is already heavy.
great tutorial.
Jan 23, 2011. 2:32 PMlongauth says:
sometimes the solvent used to carry the paint will vary from brand to brand this can also cause the krinkle effect. I've had it happen to me many times especially during a multi-coat process.
Sep 25, 2009. 7:42 AMishibashi_kid says:
nice! man get your skills up and you could start a business!
Apr 27, 2009. 6:37 PMVixen8387 says:
So awesome! Nice work! Do you think it would work better using a spray gun rather than spray cans?? (as i know how to work with cars and painting them, i'm not sure if it would work on a snowboard.. O.o;;.... same goes with the type of paint!? cause its not metal ;)
1-40 of 73next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:jonnysoups
I have an uncanny skill of putting things back together without using that extra unnecessary screw that the company put in there . I really enjoy this website, and have been a big fan for a while no...
more »
