Custom Paint an Xbox 360 Controller
 by Volgon
Give your controller a personal touch. Do you want to add some color without having to go out and spend 60 bux on a new controller or maybe don't like the choices Microsoft gave you. I am here to help you personalize your controller while still keeping it usable.
Step 1: Supplies
Some basic materials required:
Xbox 360 controller (duh)
T8H Screwdriver (or a T8 screwdriver and a watch flat head screwdriver. There is another instructible about this)
Spray Paint in the Main colors (try to get the kind I used, but there should be others that work on plastic as well)
Masking tape
Model Paint for details (I used Citadel Paint but anything should work)
Brushes
Glasses cleaner (not needed if the controller is new or fairly new)
A general Idea of what you want done
Patience (I picked up my controller too soon after adding the second color and it came off on my finger so I now have a black spot on the back)
intensafirestore says: Sep 21, 2012. 2:48 AM
If you are in the market for a custom modded controller then check out IntensaFireStore.com.
We offer 100s of custom controller designs with awesome addons like LED lighting, bullet buttons and rapid fire. We even offer do it yourself controller mods.
All of our controllers come backed by a 6 month warranty and fast shipping.
intensafirestore in reply to intensafirestoreSep 21, 2012. 2:54 AM
Just a few of the custom Xbox 360 controllers we offer.
dmadru says: Mar 3, 2011. 7:18 PM
I Made It. Duke Nukem FTW!
ironmanandy says: Aug 3, 2010. 1:21 AM
how do you paint the triggers?
Volgon (author) in reply to ironmanandyAug 3, 2010. 2:45 AM
Heh, shoulda said something about that. I paint warhammer models regularly, and i used the brushes and paints from that to paint them while they were still attached to the circuit board.
ironmanandy in reply to VolgonAug 3, 2010. 3:00 AM
oh, that woulda been easier, i wound up looking on youtube and tookk them apart. thanks for the stripes idea, i copied thtat but with all black for the controller and green for the stripes and triggers\bumpers
killersquirel11 in reply to ironmanandyNov 23, 2010. 2:03 PM
Another option would be to completely cover the rest of the circuit board with masking tape then hit the triggers with your spray paint of choice
TheBackyardInventer says: Aug 6, 2009. 12:49 AM
lol its pwn not p3wn
Valeil in reply to TheBackyardInventerJul 31, 2010. 8:27 PM
i has an gun it goes p3w p3w p3w?
starky1089 says: Sep 22, 2009. 10:12 PM
im sorry but that is a pretty bad job u did on that controller
Valeil in reply to starky1089Jul 14, 2010. 7:11 PM
The truth hurts sometimes ): lol its not a terrible job
www.RapidFireMods.com says: May 18, 2010. 7:41 PM
vaderBS245 says: Mar 31, 2010. 4:21 PM
 wats the program u have, i need it
MooseSourberry says: Oct 3, 2009. 8:46 PM
Clear coat glossy is the best i would say if you are going for a shine, but flat could work as well. Krylon fusion has recently(ish) come out with a new clear coat finish for plastic! so if you can find that is best, but anything can do it really.
MooseSourberry says: Oct 3, 2009. 8:44 PM
See.. here is where you went wrong, no offense. But you used masking tape instead of painters tape and it seeped through very badly. Also, no matter what, you are suppsed to put on the lighter coat before the darker( it really wouldn't have been very hard) but in the end, you would have had many to have done many less coats of the orange..ish color to do.. and clear coating is a must! Several clear coats, really.
Shadowfury says: Jun 30, 2009. 1:24 AM
I'm going to recommend you pick up some Dupli-Color Adhesion Promoter, even though you're using Krylon Fusion. Simply spray three coats of Adhesion Promoter on the controller after sanding and washing it. It helps the paint stick. Other than that, good instructable.
colten36 says: Jun 15, 2009. 12:51 PM
what is this program
Volgon (author) in reply to colten36Jun 15, 2009. 10:07 PM
I used Adobe After Effects, but that is a video editing program. I am just more fluent in that than Photoshop.
redstarsrbija says: May 12, 2009. 7:18 PM
jeez this is crude. i would recommend everyone planning on painting their xbox controllers to sand the surface with 400 sandpaper to leave a good surface for the paint to stick. primer would also be a good idea. clear coat is a must.
Thepage says: May 5, 2009. 6:35 PM
This inspired me to paint my "old" xbox controller check it out here
--> http://www.instructables.com/id/Old-Xbox-Controller-paint-job/
SmexyNess says: Mar 31, 2009. 6:49 PM
at first i thought that you sucked at painting it but with a closer look it has a very cool rugged beat up look. good job
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
