loading
Step 6: Outline and Detail
Remove all the masking tape. You are officially at the ugly stage.
All your blocks of colour  have uneven gaps between them. They'll be floating waiting for everything to be tied together. Luckily, you have your black Sharpie ready to go.
Start outlining. The paint marker can be messy, keep your hands up and off the marker. Smudges are a pain.
<p>I used your method to do the graphic below. This was my first attempt and I used Rustoleum paint because it was easier to find. Big mistake. I had paint crinkling problems the whole time. Not only that, but in my wisdom I thought that a clear coat would help hide the crinkling effects. It caused them where I did not have them before! You can bet that I will be using Montana next time, paying close attention to the instructions on the can, and foregoing any clear coat! However, in spite of paint difficulties, the masking tape stencils worked very well.</p>
<p>I extremely enjoyed this post! I'm considering amping up my husband's beater Passat.</p><p> Thank you for the post!</p>
<p>Good job</p>
<p>classic</p>
<p>Looks like my 65' VW Bug is gonna get some artwork! Too cool man!</p>
I've been looking around at other sources and they all seem to insist on sanding first.....whats your opinion on that? (I'm doing this on my everyday vehicle and I'd like it to last)
Very delayed response. I make sure the surface is thoroughly degreased and use a high quality/durable paint. I've never sanded nor have I had an issue with longevity. <br> <br>That being said, the oldest gig is only about 3 years old at this point. We'll see how they last over the long haul.
As soon as I get my car I think I might do something like this but small
dope art. do you exclusively use montana? how does it stand up to weather?
Pretty much Montana at all times. <br> <br>The images pictured have been going a little over a year now with no clear coat and are almost perfect. There are a lot of variables but the paint is really tough. <br> <br>Thanks for the comment.
This is the graphic from the drifting group &quot;Deadbeats&quot; <br>Amazing work!
Yep. The Deadbeat 240 was the first car I ever painted. Miss that car.
&quot;not for your mom's minivan&quot;??? I would love it if my kids painted my minivan like this! I'm sending them the link...
Simple and straight forward... and easily one of the better instructions for stenciling I've seen. Thanks. I assume you just eyeball each new layer of mask.<br><br>@curious youth, auto grade clear coat can be expensive. When I painted my motorcycle, I had a choice between two varieties, one would protect against gas spills, the other did not. The protective one was as expensive as the paint (not cheap). Sadly I could only afford the regular stuff.
Thanks for the comment. It's my first shot at one of these and I hoped it made sense :)<br><br>I've had good luck with the Montana brand clear as well as long as everything has been given ample time to dry and you mist it on. A direct spray can sometime be disastrous.
I've used spray bombs of clear acrylic with great results on many projects including boats. While I wouldn't recommend it for a high dollar custom paint job, that's not exactly what we're talking about anyway
sharpies fade quickly, way back when, when I was lettering and numbering race cars I kept a variety of paint pens in my kit, way easier than a stripping brush on smaller areas with complicated intersections. I really like the zombie in the 1st pic.. thank you for sharing
I haven't had a problem with the Sharpie oil-based paint pens but have had regular sharpie just disappear in the past. We'll see how it endures.<br><br>Thanks!
Sorry, I misunderstood you. I haven't seen sharpie oil based paint pens ! where do you get them ?
I have a local art store that carries them in an impressive assortment of colours. <br><br>There are water based as well but I can't attest to how they work. Anywhere that carries Sharpie should be able to find them.
thanks, I'll have to check around... or go online..
I have an old car just waiting to customized...hmm. the possibilities!
cant wait to get my 4 wheel drive :) it will look sick. thank you.<br><br>one tip to aid in avoiding scratches coat the whole area in a few layers of autograde clear coat and/or some sort of scratch resistant polishing/buffing compound
Awesome!<br><br>You make it look easy....
About This Instructable
61,709views
141favorites
License:
Bio: Ottawa based ne're do well. I make things. Problems, messes, you name it.
More by sideshowmassacre:Custom Painted Car Graphics
Add instructable to:
