Custom Pegboard Tool Hangers
 by Phil B
Step 3: Customizing the hammer hanger
Instead of two hangers next to one another, I bent one of the wire stubs from the previous step and welded it to the tip of one of the commercial hangers.  If you look closely, you can see that the right side of the "U" shaped piece is lower (nearer to the camera) than the left side.  This is what allows the hammer to hang with the handle straight and vertical as in the Introduction photo.
In the second photo below you can see how the "U" shaped piece aligns with the contours of the hammer.  I used this process to determine how much angle to use on the piece I bent in the setup for welding it to the commercial hanger.
In the third photo below I placed my customized hanger into the vise to adjust the angle on the customized hanger so the hammer's handle hangs straight up and down.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
