3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom Play Sword and Scabbard
I love sword play, but not the limited selection of foam or padded swords sold. PVC and pipe insulation are  fine, but the swords you can make with them are limited. However, with a bit of plywood and a saw, you can make custom sword of any shape or size.
*Disclaimer: Swords of any kind are dangerous! This sword is padded but it WILL hurt if you get hit hard. Never use it to hurt another living being or someones property! I am not responsible for what you do with these instructions! They are ment only for informational purposes!*
Step 1Tools and Materials
Tools and Materials
To make a sword using this method you will need:
Tools:
A scroll saw or jigsaw (I used a scroll saw, but for larger blades a jig saw is better)
A Rotary tool with a sanding head and a cutting head
A drill/driver
Scissors
Materials:
3 1" screws (you may need more depending on the blade size)
1/2" PVC pipe
1/2" plywood
Foam pipe insulation
Duck tape
Cardboard
Optional but recommended:
Large graph paper
Box cutter
8 comments
Dec 22, 2011. 5:35 PMh8864 says:
its called DUCT TAPE. DUCK TAPE is a brand
Jul 17, 2011. 6:56 PMdoomsdayltd says:
hmm more like a halberd than a sword but i like the idea!
Jul 19, 2011. 3:21 PMdoomsdayltd says:
ah, i thought it looked like that. but yea, halberd's are much longer....so a scabbed for one is redonkulus
Oct 19, 2010. 6:58 PMdragonsmithy says:
its a good idea and i understand were you are coming from with the idea. Another idea is to use poly foam planks, i use two inch thick ones to make shields and weapons from. Just trying to pass one tips from one foam smith to another.
Aug 31, 2010. 12:36 AMLt. Duct Tape says:
Wood is arguably the WORST core you can use for a padded sword of any kind. It's illegal in nearly EVERY game for a reason: It breaks. It splinters. Especially plywood. And with that "half-tang" construction, I have no doubts that sword will break at the handle. It's a nice idea, but don't expect any field-martial or Reeve to allow that sword onto a LARPing field.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pie R []ed
Being yourself is the way to be. I'm proud of nonconformity!
