Introduction: Custom Pocket Slim Gadget Stand
Picture of Custom Pocket Slim Gadget Stand
First generation gadgets are exciting, but waiting for available accessories is very frustrating. In this instructable, I'll show you how I create custom fitted stands for my new gadgets. They are pockatable, adjustable, and best of all you can customize it to give it your personal touch! A great conversation starter, too!
In this instructable, I will show you how I made one for my phone - a Galaxy Note 4.
What you need:
  • Caliper
  • 3D printer
  • 3D modeling software - just about any would do. I personally use Autodesk Fusion 360, but I'll demonstrate Tinkercat in this tutorial because it's very easy to learn.
Step 1: Decide Where to Place It.
Picture of Decide Where to Place It.
Before measuring, I decide where the stand should be. Most gadgets have buttons, ports and slots that I need to avoid. Also, many of them are not simple rectangles. This Galaxy Note 4, for example, actually has a "waist."
Step 2: Measure Precisely
I use a caliper to get better precision. Measuring precisely saves you a lot of headaches. In most cases, I have to iterate a few versions to get a perfect friction fit.
Things to pay attention when measuring:
  • Zeroing frequently
  • Most gadget casings are a bit flexible, so it'd buck a little when you measure it. Make sure the measurements are all about the same tightness.
  • To determine measurement precision, take your nozzle size into consideration. If your nozzle is standard 0.4mm, there's no reason to measure to 0.01mm
Step 3: Create 3D Model and Print!
Picture of Create 3D Model and Print!
Create a 3D model using the measurement. I usually just do a simple extrusion of the profile.
Tips:
  • Watch out for screen clearance. Not only the screen shouldn't be blocked, I also create a little bevel to give some room for my finger at the edge.
  • Thickness depends on the material strength. For PLA, I used about 4mm.
  • To reduce bulk, hallow it out but keep enough structural strength. Inner fillets and triangles are useful.
Usually I need to iterate a few times to ensure a great fiction fit. Not only does this help secure it, this also help create adjustable angles.
Step 4: Customize!
Picture of Customize!
This is when you can add more personal touch to your cool little gadget stand. Add some text, logo, clip art, use your imaginations!
This is a great conversation piece. Try it!
Have fun!
TroyH21 (author)2016-01-29
I like the design but it can use a simple fix. Make i able o fit many types of thick phone
cfishy (author)TroyH212016-01-29
What's the simple fix? Would that makes it bigger or fit loosely?
cfishy (author)cfishy2016-01-29
Also, would you be able to fit multiple phones without blocking the buttons, screen and speakers in various places?
lbone1 (author)2015-12-31
If the price was reasonable I'd pay you to make one for my kindle fire 10in
cfishy (author)lbone12015-12-31
I can make you one, but in order to friction fit, I need to have the physical device. Measurements won't do because 3d prints are not dimensionally exact.
Although now you made me think I can design a stress relief to increase its tolerance? I'll try to make some and let you know!
About This Instructable
4,814views
69favorites
License:
More by cfishy:3D Printed Custom Funnel3D Printed Hex Bit HandleTabletop Hydroponics With 3D Printed Ebb and Flow Fittings
Add instructable to:
