Here is a project that I did a few years ago and now decided to show it to you!
It is quite cheap and easy to build and does not require a lot of sklls. On top of this, the result is fun and very enjoyable.
Let's make RC pipes, people!
Step 1: Idea
The idea is to mix all the components you see here and make the Pipe controlled - an RC Pipe!
You can use a variety of cordless drills for example. The same is with the wheels and the pipe. It could be shorter or with a bigger diameter. It all depends on how you want it to be.
I used two medium sized drills - some cheap ones to be honest. They were powered with 12V batteries one of which is in the RC Pipe.
d3h says: Jul 9, 2012. 4:14 AM
my wookie says: Nov 26, 2012. 6:42 PM
wouldn't it be easier to use commercial RC stuff (like 360 servos?)
hertzgamma (author) says: Nov 27, 2012. 1:57 PM
Definitely yes, it's just the whole idea. It is possible to do it with servos as well as with motors.
wfelix says: Jul 20, 2012. 4:57 AM
very good idea!
The tail may be a little whell too, to minimize the friction.
imakethings says: Jun 4, 2012. 11:58 AM
Very good! i had made a mechanical version of this in my childhood using a rubber band..!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
